"An error has occurred: please check your hardware"
Posted 28 August 2010 - 12:07 AM
Posted 28 August 2010 - 12:09 AM
Posted 28 August 2010 - 12:21 AM
Posted 28 August 2010 - 12:35 AM
Posted 28 August 2010 - 01:13 AM
But, I can read RFID tags.
Posted 01 September 2010 - 03:26 AM
Posted 22 December 2010 - 06:58 PM
I find myself in the same situation where VS2010 fails deploying to the netduino and only shows "Error 1 An error has occurred: please check your hardware."
netduino configuration:
Pinging... TinyCLR
HalSystemInfo.halVersion: 4.1.2821.0
HalSystemInfo.halVendorInfo: Netduino (4.1.1.0 a2) by Secret Labs LLC
HalSystemInfo.oemCode: 34
HalSystemInfo.modelCode: 177
HalSystemInfo.skuCode: 4096
ClrInfo.clrVersion: 4.1.2821.0
ClrInfo.clrVendorInfo: Netduino (4.1.1.0 a2) by Secret Labs LLC
ClrInfo.targetFrameworkVersion: 4.1.2821.0
SolutionReleaseInfo.solutionVersion: 4.1.1.0
SolutionReleaseInfo.solutionVendorInfo: Netduino (4.1.1.0 a2) by Secret Labs LLC
SoftwareVersion.BuildDate: Sep 29 2010
SoftwareVersion.CompilerVersion: 400771
FloatingPoint: True
SourceLevelDebugging: True
ThreadCreateEx: True
I have attempted the following to no avail:
- Erased the application that I thought may have caused the issue using MFDeploy
- Reflashed the firmware with v4.1.1.0 alpha 2
- Re-installed the netduino 4.1 SDK
Cheers,
-Fabien.
Posted 22 December 2010 - 07:13 PM
How big is your application? The size should be displayed in the Output window when you compile it... This error will also occur if it's too big to fit into flash (which would occur if, say, one added a huge assembly or two to a project).
Posted 22 December 2010 - 07:36 PM
Posted 22 December 2010 - 08:51 PM
Posted 22 December 2010 - 09:33 PM
Ok, I figured it out! It turns out that some folders needed to be "excluded from the project".
So were those resources too big?
P.S. Looks like a cool project!
Posted 22 December 2010 - 11:15 PM
The resources are actually quite small and only add up to 719 bytes. So, that's wasn't the issue.
The project is indeed a fun one ;-)
Posted 22 December 2010 - 11:22 PM
C64 Space Invaders on a LED Matrix display?The project is indeed a fun one ;-)
Posted 23 December 2010 - 07:00 PM
Lol! That's one possible application for the project ;-)
Posted 27 December 2010 - 05:06 AM
Posted 27 December 2010 - 05:19 AM
What this message mean?
Hi Takao,
What device have you selected for deployment (in Project Properties > .NET Micro Framework > Target)?
Also, what type of Netduino do you have?
Posted 27 December 2010 - 05:37 AM
Hi Takao,
Hi, chris,
Thank you for very quick answer.
Then, I re-start my PC then It is now the blink sample working. No-problem.
I will try to use your netduino for this,
http://www.rcgroups....&postcount=2165
Takao
Posted 07 September 2012 - 02:44 AM
#19
Posted 25 September 2012 - 04:52 PM
This same thing happened to me tonight... what fixed my problem was just creating a new project.
-Bonnie
Was having the same problem with my Netduino Go and a new project resolved the problem. Thanks Bonnie.
#20
Posted 20 April 2014 - 08:29 AM
I just bought a NetDuino Plus 2
Got things up and running with VS 2013.
Build a few applications and all was well.
Then I tried flashing the new firmware......
I went through the process described and everything seemed to go well. No errors. I couldn't choose the Verify option at the time of flashing the firmware - it said something to the effect of being in dfu mode.
When attempting to deploy code to my Netduino, I'm getting the error mentioned in the original post and I've tried the suggestions that pertain. However, it looks like I need to re-flash the firmware but my Netduino needs to be in a state such that I can't
When I run MFDeploy
I sees the USB device
If I do a Ping I see
What do I do from here?
Any help would be greatly appreciated.
Shiv
