USB Power and 9volt battery life
Posted 27 July 2011 - 01:42 PM
Posted 27 July 2011 - 02:46 PM
Posted 27 July 2011 - 02:51 PM
Posted 27 July 2011 - 03:44 PM
Consider that a good 9V battery (alcaline, non-rechargeable) is able to give up to 500mAh. It means 500mA for one hour, or 50mA for 10 hours. That's theoretical, but it gives a rough idea on the capacity.
The Netduino plus itself needs about 80mA. One led could take 15mA (it depends on the resistor and the voltage applied), so 10 leds is about 150mA.
Under these conditions your battery will die in a couple of hours.
You won't be happy, but the manufacturer of batteries does!
Posted 27 July 2011 - 03:46 PM
As Mario mentioned, you can roughly estimate the duration from the battery capacity. For more reasonable results, you'd need to know battery discharge curve, because the real capacity may vary significantly depending on the current drawn (example). If the size/weight is not the constraint, AA or AAA batteries will give you higher capacity...but I don't know the right numbers and formula to do it myself.
Posted 27 July 2011 - 04:09 PM
Bummer! How many mAh do six 1.5volt batteries have?
Since you put them in series, you want to know how much one has, and you can find that out at http://en.wikipedia....wiki/AA_battery.
Posted 27 July 2011 - 04:25 PM
10 leds at 20mah = 200mah
80mah for Netduino plus
Six 1.5v alkaline batteries at 2700mah
So, I'll get around 9.6 hours with six 1.5v alkaline (or 7ish hours with 2000mah eneloops). I realize this isn't an exact science, but is that more or less correct?
Thanks for being patient and giving me the links to wikipedia. Sometimes I forget to go there first!
Posted 27 July 2011 - 05:22 PM
- powered by battery (no recharge possible);
- the battery should ensure an average lifetime of about five years;
- ...others...
The funny part of the story was about the lifetime. The actual duration was not limited by the circuit itself, but the natural auto-discharge of the battery itself!
Posted 28 July 2011 - 04:12 PM
With my project, I eventually gave up and used Arduino Fio with LiPo battery and the device sleeps for 2seconds, wakes up check status and if nothing to do, goes back to sleep. By that I extended the lifetime of a 2000mA battery by 10 folds at least. With the Fio being extremely battery friendly I completed the project and battery last there for 4 months already without recharging. Still, I felt bad for not doing it with the Netduino (defeat the purpose I called it).
Just a curious guy
Posted 10 September 2011 - 04:02 PM
Posted 11 September 2011 - 03:51 AM
You must think in "current" terms, instead of voltage.Ok, now that my project is complete, been thinking about power more. Since the LEDs only take 3.3v, does that change the calculations since I'm feeding the netduino plus 9 volts? To think more, what if I fed the netduino plus 12 volts? I'm sure it's easy, but I'm hopeful that maybe this will somehow factor into getting more life than mentioned here.
For instance, even 3.3V powered, if your led sucks 10mA, then your battery will have to feed 10mA.
This leads a lot of energy wasted, because most of the time the voltage is divided/regulated using simple circuits (which is based on wasting energy).
However, there are sophisticated power supplies that have a high efficiency. Is it worthwhile?
