Rotary Encoder Switch class
#1 Adam Clifford
Adam Clifford
  • 18 posts
Posted 26 July 2011 - 03:33 PM
Hi All,
Here is a state machine based rotary encoder switch with push button that is interrupt bassed.
you supply the two pins that output the pulses (grey code) and the pin that is used for the push switch, and when the the switch turns the class fires an event based upon the direction of motion, (clockwise or anti clockwise)
here is the code any improvements feel free to point out.
namespace RotaryEncoderSwitch
    public class RotarySwitch
        private static readonly bool[] stateOne = new bool[2] {false, false};
        private static readonly bool[] stateTwo = new bool[2] {false, true};
        private static readonly bool[] stateThree = new bool[2] {true,true};
        private static readonly bool[] stateFour = new bool[2] {true,false};
        private static bool[] oldState = new bool[2];
        private static bool[] newState = new bool[2];
        private static InterruptPort _pinAInterrupt;
        private static InterruptPort _pinBInterrupt;
        private static InterruptPort _switchPinInterrupt;
        public delegate void ClockwiseEventHandler();
        public delegate void CounterClockWiseEventHandler();
        public delegate void ButtonPushedEventHandler();
        public static event ClockwiseEventHandler ClockWise;
        public static event CounterClockWiseEventHandler CounterClockWise;
        public static event ButtonPushedEventHandler ButtonPushed;
        public RotarySwitch(Cpu.Pin pinA, Cpu.Pin pinB, Cpu.Pin switchPin)
            _pinAInterrupt = new InterruptPort(pinA, true, Port.ResistorMode.Disabled, Port.InterruptMode.InterruptEdgeBoth);
            _pinBInterrupt = new InterruptPort(pinB, true, Port.ResistorMode.Disabled, Port.InterruptMode.InterruptEdgeBoth);
            _switchPinInterrupt = new InterruptPort(switchPin, true, Port.ResistorMode.Disabled, Port.InterruptMode.InterruptEdgeHigh);
            _pinAInterrupt.OnInterrupt += new NativeEventHandler(_pinAInterrupt_OnInterrupt);
            _pinBInterrupt.OnInterrupt += new NativeEventHandler(_pinBInterrupt_OnInterrupt);
            _switchPinInterrupt.OnInterrupt += new NativeEventHandler(_switchPinInterrupt_OnInterrupt);
            oldState[0] = _pinAInterrupt.Read();
            oldState[1] = _pinBInterrupt.Read();
        static void _switchPinInterrupt_OnInterrupt(uint data1, uint data2, DateTime time)
            if (ButtonPushed != null)
                ButtonPushed();
        static void _pinAInterrupt_OnInterrupt(uint data1, uint data2, DateTime time)
            newState[0] = data2 == 1;
            newState[1] = _pinBInterrupt.Read();
            CheckDirection();
        static void _pinBInterrupt_OnInterrupt(uint data1, uint data2, DateTime time)
            newState[0] = _pinBInterrupt.Read();
            newState[1] = data2 == 1;
            CheckDirection();
        private static void CheckDirection()
            int newStateInt = 0;
            int oldStateInt = 0;
            int direction = 0;
            if (newState == stateOne)
                newStateInt = 1;
            if (newState == stateTwo)
                newStateInt = 2;
            if (newState == stateThree)
                newStateInt = 3;
            if (newState == stateFour)
                newStateInt = 4;
            if (oldState == stateOne)
                oldStateInt = 1;
            if (oldState == stateTwo)
                oldStateInt = 2;
            if (oldState == stateThree)
                oldStateInt = 3;
            if (oldState == stateFour)
                oldStateInt = 4;
            direction = newStateInt - oldStateInt;
            if(direction > 0)
                if (ClockWise != null)
                    ClockWise();
            if(direction < 0)
                oldState = newState;
                newState = null;
                if(CounterClockWise != null)
                    CounterClockWise();
            newState = null;
            return;
#2 AlfredBr
AlfredBr
  • 138 posts
  • LocationConnecticut, USA
Posted 26 July 2011 - 05:58 PM
Hi All,
Cool. Do you have a link to a rotary encoder that you have used with this code?
#3 Dan Morphis
Dan Morphis
  • 188 posts
Posted 26 July 2011 - 08:06 PM
Alfred, this list of encoders on Mouser will work.
-dan
#4 Adam Clifford
Adam Clifford
  • 18 posts
Posted 27 July 2011 - 07:23 AM
Thanks Dan I am using the one from sparkfun http://www.sparkfun.com/products/9117 Adam Clifford
#5 PhilG
PhilG
  • 42 posts
  • LocationMaine
Posted 04 November 2011 - 09:36 PM
             if(direction < 0)
                newState = null;
                    CounterClockWise();
            newState = null;
            return;
Why are the states changed in the CCW routine?
