I've read and looked at your code: It's all good!
The problem seems to be with the conversion from string to byte.
I think it's a bug in the SDK, but I'm not 100% sure.
I have not yet found a way to convert Char or String to Byte without crashing.
For one project I ended up using this workaround:
Private Function GetByteFromCharacter(ByVal myChar As String) As Byte
Select Case myChar
Case " "
Return 32
Case "!"
Return 33
Case """"
Return 34
Case "#"
Return 35
Case "$"
Return 36
Case "%"
Return 37
Case "&"
Return 38
Case "'"
Return 39
Case "("
Return 40
Case ")"
Return 41
Case "*"
Return 42
Case "+"
Return 43
Case ","
Return 44
Case "-"
Return 45
Case "."
Return 46
Case "/"
Return 47
Case "0"
Return 48
Case "1"
Return 49
Case "2"
Return 50
Case "3"
Return 51
Case "4"
Return 52
Case "5"
Return 53
Case "6"
Return 54
Case "7"
Return 55
Case "8"
Return 56
Case "9"
Return 57
Case ":"
Return 58
Case ";"
Return 59
Case "<"
Return 60
Case "="
Return 61
Case ">"
Return 62
Case "?"
Return 63
Case "@"
Return 64
Case "A"
Return 65
Case "B"
Return 66
Case "C"
Return 67
Case "D"
Return 68
Case "E"
Return 69
Case "F"
Return 70
Case "G"
Return 71
Case "H"
Return 72
Case "I"
Return 73
Case "J"
Return 74
Case "K"
Return 75
Case "L"
Return 76
Case "M"
Return 77
Case "N"
Return 78
Case "O"
Return 79
Case "P"
Return 80
Case "Q"
Return 81
Case "R"
Return 82
Case "S"
Return 83
Case "T"
Return 84
Case "U"
Return 85
Case "V"
Return 86
Case "W"
Return 87
Case "X"
Return 88
Case "Y"
Return 89
Case "Z"
Return 90
Case "["
Return 91
Case "\"
Return 92
Case "]"
Return 93
Case "^"
Return 94
Case "_"
Return 95
Case "`"
Return 96
Case "a"
Return 97
Case "b"
Return 98
Case "c"
Return 99
Case "d"
Return 100
Case "e"
Return 101
Case "f"
Return 102
Case "g"
Return 103
Case "h"
Return 104
Case "i"
Return 105
Case "j"
Return 106
Case "k"
Return 107
Case "l"
Return 108
Case "m"
Return 109
Case "n"
Return 110
Case "o"
Return 111
Case "p"
Return 112
Case "q"
Return 113
Case "r"
Return 114
Case "s"
Return 115
Case "t"
Return 116
Case "u"
Return 117
Case "v"
Return 118
Case "w"
Return 119
Case "x"
Return 120
Case "y"
Return 121
Case "z"
Return 122
Case "{"
Return 123
Case "|"
Return 124
Case "}"
Return 125
Case "~"
Return 126
Case Else
Return 32
End Select
End Function
I guess things will look better for VB when we're out of Beta...
