Netduino - WiFi
Posted 22 July 2011 - 12:49 AM
- Goat likes this
Posted 22 July 2011 - 07:58 AM
Posted 22 July 2011 - 01:36 PM
Posted 22 July 2011 - 07:14 PM
Posted 23 July 2011 - 03:18 AM
The project files are attached. There are comments in the project indicating how to connect the Gainspan module to the Netduino. The code contains very little error handling, as this is currently in the experimental stage.
Here are links to the documents I consulted to put this together:
- Datasheet: http://dlnmh9ip6v2uc...eet ver 1.0.pdf
- Command Set: http://dlnmh9ip6v2uc...ide ver 5_3.pdf
- Sparkfun breakout board Schematic: http://dlnmh9ip6v2uc...reakout-v11.pdf
Posted 24 July 2011 - 12:01 AM
- deven likes this
Posted 24 July 2011 - 08:43 AM
Posted 25 July 2011 - 01:05 AM
Posted 26 July 2011 - 05:04 PM
Posted 27 July 2011 - 12:52 PM
Dumb question. Can this be used with a regular Netduino (not Plus)?
Yes, this can be used with the regular Netduino as well.
Posted 01 August 2011 - 01:09 AM
Posted 23 August 2011 - 10:04 AM
Posted 24 August 2011 - 02:45 AM
Hi Nick,
I ordered a GainSpan module from SparkFun, and thanks to your code was up and running quickly. I haven't done any systematic measurements yet, but got the impression that the module's throughput is rather low.
I thought of using bulk mode transfers, which may be faster, but the documentation (Serial_to_WiFi_Adapter_Guide ver 5_3.pdf) appears inconsistent. I tried the command AT+BDATA=1 to enable bulk mode, and then ESC 'Z' for sending data, but got error messages. My module's firmware version is 2.2.4, btw.
Do you have experience regarding the module's throughput?
Thanks and best regards
Cuno
Hi Cuno,
I am glad to hear you were able to get the Gainspan module communicating. To enable bulk data mode, you need version 2.3.1 of the Gainspan firmware. To obtain version 2.3.1, you would need to sign an NDA with Gainspan for the firmware update. When you say the throughput is low, do you mean the Wi-Fi to serial conversion? You might try adjusting the Baud Rate of the serial connection. Please update me on how you're doing with it. Good luck.
Posted 12 September 2011 - 09:39 PM
Posted 02 October 2011 - 05:16 PM
at+httpconf=20,User-Agent: Mozilla/4.0\r at+httpconf=3,keep-alive\r at+httpconf=11,<myhost>\r at+httpconf=7,application/x-www-form-urlencoded\r at+httpopen=<myhostip>\r at+httpsend=0,3,10,/test_post.php,23\r\x1BHname=myName&info=myInfo
Any suggestions? I'm not sure what to try next.
Posted 07 October 2011 - 02:36 AM
I'm using the gainspan 1011. I followed your source code and have tcp working nicely, thanks! I'm trying to get the httpsend feature working to send an http post. I setup a php script that accepts two fields and I've verified it works using putty. So far, the php script is telling me I'm sending an empty message. So, I'm definitely talking to the server, just not sending any data. I think maybe I've got the escape sequence incorrect. Here's the relevant commands I'm sending the gainspan:
Hi, unfortunately I have not used the built-in http features of the Gainspan. For my Gainspan projects I rolled my own http communications.
Posted 14 October 2011 - 01:16 AM
I figured out the problem was I left out the command which sets the data length, fifth line below. Here is the working code snippet:
at+httpconf=20,Mozilla/4.0\r at+httpconf=3,keep-alive\r at+httpconf=11,enginuitydiagnostics.com\r at+httpconf=7,application/x-www-form-urlencoded\r at+httpconf=5,23\r at+httpopen=<myhostip>\r at+httpsend=0,3,10,/test_post.php,23\r\x1BHname=myName&info=myInfo
Posted 16 October 2011 - 06:58 PM
#19
Posted 16 October 2011 - 11:43 PM
I have just got a gainspan module from sparkfun, and I wondered if you could help...
Firstly can you tell me which version of the firmware do I need (I have the NDK now), I have downloaded both but am not sure which one to use; the Mxp or MEE?
Also how do I then update the firmware?
Finally do you have an example web script as I have not really done much with websites before and don't really know where to begin with that side?
Many thanks,
Andy
Andy,
Out of the box, you do not need to update the firmware. If you need the current functionality, such as Bulk Data mode and others, you'll need to update the firmware.
The part number should be written on the device. Mine is a GS1011MIP, so I would use the MxP firmware. The part number just indicates whether it uses an internal or external Power Amplifier (PA) and whether it uses an external or PCB antenna. For example, an MIP has an internal PA with PCB antenna. An MEE has an external PA with External antenna. See also http://www.gainspan....e/s_modules.php
I update the firmware using a 3.3v USB-to-TTL adapter and the communication software provided with the Gainspan software download. I can't remember the name of the software at the moment but it is included in the download, as long as you have a login and have signed the non-disclosure agreement. Just plug the USB end of the adapter into the computer and wire the 3.3V, Tx, Rx, and Gnd from the ttl adapter to the corresponding pins on the Gainspan module, with Tx to Rx, and Rx to Tx.
As for the example web script, maybe describe what you're trying to do exactly and I can try to help.
Nick
#20
Posted 17 October 2011 - 02:32 PM
