Edited by Goat, 20 July 2011 - 11:35 PM.
Another COM port problem
Started by Goat, Jul 20 2011 10:32 PM
Posted 20 July 2011 - 10:32 PM
Hi all!
I am a noob at netduino but have quite an expertise in C# and currently I am porting a small project that was working on my PC to the netduino. This project makes my PC communicate with a device using a Prolific USB-to-COM port; specifically, request some info and get back results. The problem is that upon compiling this 20-line code to netduino, the device I want to "talk" to does not respond. Here is some more info:
- I use the CuteDigi COM shield which uses pin 0 and pin 1 of the netduino (so COM1 is used).
- COM initialization is at 57600, 8, N, 1.
- Netduino sends the appropriate byte sequence to the device and the device does NOT answer.
- PC sends the appropriate byte sequence to the device and the device answers back.
- PC and Netduino can send info to each other when connected with no problems.
- netduino firmware version is 4.1.0.6
What am I missing here? Any help would be gladly appreciated...
PS1: The device I connect to does not respond if it gets a wrong byte sequence or, of course, if it gets no bytes at all...
PS2: Could this be voltage related? Does the netduino work on 5V signals or 3.3V signals for COM port operation?
Posted 21 July 2011 - 07:16 AM
Welcome to the community.
The Netduino will tolerate 5V input but the output is 3.3V.
Posted 21 July 2011 - 08:17 AM
Pins 0 and 1 are fixed on the shield I'm afraid, any chance to set them to pins 2 and 3 temporarily? I know COM1 has some limitations compared to COM2, perhaps this is one of them (although 57600,8,N,1 is quite common)
