how to a read temperature from the web
No replies to this topic
#1 laik777
laik777
  • 12 posts
Posted 19 July 2011 - 02:35 PM
Hey
I am new here.
I would like to know how to read a temperature from the web.
This is my program to read the temperature and it s working well:
using System.Net;
using System.Net.Sockets;
namespace i2c_bus_temp
           byte[] buffer_read = new byte[2];
           byte[] buffer_write = new byte[1];
           I2CDevice.Configuration config = new I2CDevice.Configuration(0x48, 100); // naslov naprave v   hexa,binarno je1001000, zadnji trije določajo A2 A1 A0.
          I2CDevice RTC = new I2CDevice(config);
           buffer_write[0] = 0x00;
           I2CDevice.I2CReadTransaction tran_read = I2CDevice.CreateReadTransaction(buffer_read);
           I2CDevice.I2CWriteTransaction tran_write = I2CDevice.CreateWriteTransaction(buffer_write);
               I2CDevice.I2CTransaction[] tran = new I2CDevice.I2CTransaction[] { tran_write };
               int data = RTC.Execute(tran, 100);
               Debug.Print("\nThe number of data transfered is: " + data.ToString());
               tran = new I2CDevice.I2CTransaction[] { tran_read };
               int tempH;
               int tempL;
               tempH = buffer_read[0]*8;
               tempL = buffer_read[1]/32;
               Debug.Print("\nThe number of data transfered is: " + (tempH+tempL)/8.0 +" °C");
               Thread.Sleep(1000);
I will be hapy if someone could connect my temperature to the web with using this program:
using Blinq.Netduino.Web;
namespace ServerExample
    /// <summary>
    /// Example for using the Blinq.Netduino.Webserver class
    /// </summary>
       static InputPort bb = new InputPort(Pins.ONBOARD_SW1, false, Port.ResistorMode.Disabled);
       static WebServer server = new WebServer(80);
           bool buttonState = false;
           server.CommandReceived += new WebServer.CommandReceivedHandler(server_CommandReceived);
           server.AllowedCommands.Add(new WebCommand("button", 0));
           server.Start();
       private static void server_CommandReceived(object source, WebCommandEventArgs e)
           Debug.Print("Command received:" + e.Command.CommandString);
           switch (e.Command.CommandString)
               case "button":
                       e.ReturnString = "<html><body><p>Butoon je v stanju: " + !bb.Read() + "</p></body></hmtl>";
                       break;
Thanks in advance:)
Edited by Stefan, 19 July 2011 - 02:59 PM.
Added [code] tags
