this is probably a simple one - if a part is advertised as an LCD which interfaces to microcontrollers through a serial bus interface - do I need additional parts? Is so what would they be?
The advert detailed spec says :-
It uses the PCD8544 controller. The PCD8544 is a low power CMOS LCD controller/driver, designed to drive a graphic display of 48 rows and 84 columns. All necessary functions for the display are provided in a single chip, including on-chip generation of LCD supply and bias voltages, resulting in a minimum of external components and low power consumption. The PCD8544 interfaces to microcontrollers through a serial bus interface.
