first of all, thanks for all your effort and thanks for this great netduino-board. It has never been so easy to see results with a micro controller.
Currently i am trying to interface the ADNS-2610 Optical Mouse sensor through the SPI. The class is ready an works almost. Unfortunately i have to wait 100micro seconds between the write and read-operation. That is currently not possible with the provided WriteRead-Method of the SPI-Class in the API (i guess that wont change anytime soon?).
Bitbanging in the range of milliseconds with the API is a no-go, as i found out after implementing it
Then i found Corey and his great library, thank you for your awesome work (even the BitBangig already there
If you currently compile your BitBanger-Class you get an exception
{System.FormatException: Index (zero based) must be greater than or equal to zero and less than the size of the argument list. at System.Text.StringBuilder.AppendFormat(IFormatProvider provider, String format, Object[] args) at System.String.Format(IFormatProvider provider, String format, Object[] args) at System.String.Format(String format, Object[] args) at Kosak.SimpleNGen.util.Util.AsFormat(String item, Object[] args) in D:\Development\TBOT\simpleNgen1.4\SimpleNGen\util\Util.cs:line 11}
Problem is a typo in LdindU1 where it should be
return "LDINDU1 {0},[{1}]".AsFormat(Value, Pointer);
One question remains - is there any current Netduino-Plus Firmware with the NGen-Entry point out there? I would appreciate that very much as it seems that i wont be able to compile it myself...
Species8732
