Hi Stuart Crawshaw,
Welcome to the boards!
In MFDeploy, if you click Target->Device Capabilities, what does it output?
And which firmware version did you had before, and to which version you're trying to upgrade?
Thanks for the reply. If i run the Device Capabilities option i get:
which does seem like it has updated. But what is concerming me is that it may not be fully updated/stable as all the output from MFDeploy is not there.
I have updated from the stock FW when i bought the unit, to the 4.2 beta 1 version (including the bootloader), then tried a non-beta (4.1.0.6 i think) and that had the same output result in MFDeploy and now I have tried again with the beta (as the above output would suggest.
But as mentioned before, due to the output (or lack thereof) i am dubious as to whether it has updated correctly.
Hi Stuart,
It looks like you're all set. Sometimes MFDeploy needs a quick disconnect/reconnect of your device after updating...the Device Capabilities info (and the fact that your Netduino is booting into the TinyCLR runtime) means that it updated correctly.
Please go ahead and deploy some apps to your Netduino. If it gives you any troubles, we'll be here to help sort it out. The good thing about Netduino is that, since it's open source, you can erase and reflash it any way you'd like...and there's a community of nice folks here to help if you run into troubles.
Awesome, thanks confirming that all is ok.
Just to confirm, MFDeploy doesnt need to give a full output for the update to be successful? (as I tend to only get "Chk s" or "Chk signa" but never a full line of text...
Hi Stuard,
When you went from 4.1.x to 4.2b1 you also updated the bootloader. When you tried to go back to 4.1.x, did you wrote back the older bootloader as well?
-edit- I see it's already solved? Darn you're fast!
MFDeploy sometimes doesn't print the entire text...there's some buffering going on. But the .NET MF runtime does a bit of signature checking each time you boot it. There are multiple levels of verification built in.
I did indeed. And just to confirm, i verified the written bootloader with the file using SAM-BA.
Thats good to know,
Seems I am good to go. i just deployed the very well known "blinking LED" code and it deployed and run successfully.
I have however noticed that when deploying, i will sometimes get a message along the lines of "Debbugger not in an initilized state; rebooting" but it does not seem to do anything.
It it just a case of disconnecting the device/pushing the reset button at this point and trying again?
Yes, please try that.
Also...we created a patch in the v4.1 firmware which helped fix this issue. We removed the patch in v4.2, since Microsoft incorporated a permanent fix for the issue there. If you are running into new issues with 4.2, we'd love to know more...so we can update the bug ticket at netmf.codeplex.com.
Thanks for helping test 4.2!
Running 4.2, i still get the Debugger not in an initialized state, rebooting message.
Hitting the reset button does nothing, pulling the power and re-inserting it seems to move things along.
Hi Stefan, Stuart:
It appears that the original issue pre-dated use of the CodePlex issue tracker. Could you please post a bug report on this at netmf.codeplex.com (stating that 4.1 worked, but 4.2 does not) and we'll fill Microsoft in on the details? The lead engineers on the NETMF team will remember the issue, as they spent considerable time solving it.
