I have a situation where the supply voltage of an existing system is 16V. I'm replacing the circuit board with my own one that contains a Netduino Mini. Would I need to add an additional regulator, or should it be able to handle it?
I ask because I notice that the Mini's regulator can handle up to 20V (but of course it depends on the current draw, which isn't specified for the Mini).
Would 16V be too high for a Mini?
Started by BitFlipper, Jun 17 2011 12:22 AM
5 replies to this topic
Posted 17 June 2011 - 12:22 AM
Posted 17 June 2011 - 02:11 AM
I wouldn't push quite that much voltage in. Can you regulate it down to 5V and push it through the 5V pin?
Posted 17 June 2011 - 02:13 AM
Hi BitFlipper,
I'd highly recommend staying within the 7.5-12.0VDC range (and preferably at the lower end of that range). There's no room for heatsinking on the Mini--and a higher input voltage like 16VDC will just mean more heat.
All the Minis we've built to date use power regulators which are technically rated to 20VDC. That's a bit of overengineering, but it's not something that we test for--and not something that's always guaranteed to be poopulated that way.
Posted 17 June 2011 - 07:36 AM
OK fair enough. I'll just stick an LM7805 in front of it and feed that into the 5V pin.
Thanks for the help.
Posted 17 June 2011 - 09:13 AM
You've basically got two options - add a very cheap 7805 or risk it and see if you overheat the onboard regulator and destroy the Mini. I know what I'd pick.
