Attach a PS2 Keyboard to Netduino Plus
Posted 16 June 2011 - 10:36 AM
Posted 16 June 2011 - 10:40 AM
Posted 16 June 2011 - 11:10 AM
Posted 16 June 2011 - 11:18 AM
Check http://www.sparkfun.com/distributors and search for Italy. There are several distributors.Yes, it's perfect ... now i must found an european distributor (italy preferred) ... it will be hard
No problem at all, it's quite a general question, not Plus specific so far. I moved it to Netduino Plus for youPS: sorry, i've seen only now that there is a section on the forum for the netduino plus :\
Posted 16 June 2011 - 11:33 AM
Thank you.
I've checked all italian distributors, no way ... i'm going to check all german distributors.
Anyway, for another long-term project i need to use a barcode ... so, in the end, i'll probably use a netduino plus with a ps2 attached (if it's correctly supported)
Posted 16 June 2011 - 11:35 AM
It seems that the PS/2 interface looks very close to the SPI one. So far, I guess should be pretty easy to connect either a keyboard or even a mouse to the Netduino (any model).
Please check at these docs.
Posted 16 June 2011 - 11:43 AM
Ohh that looks interesting actually! Not exactly like SPI because one pin is used for both Rx and Tx and there is no CS pin, but it looks like the host defines the clock and that makes it possible for Netduino to work with.Hi Daniele and Stefan.
-edit- I see a success-post here: http://forums.netdui...rd-timing-woes/
Requires modification to the firmware though. Perhaps it would be nice if PS/2 support would be built-in the firmware. Chris, reading this?
Posted 16 June 2011 - 02:05 PM
Posted 16 June 2011 - 02:11 PM
I always advise to use stable soft/firmware, especially when you're new to Netduino. On the other hand, it's always possible to reload stable firmware when you encounter any problems. So no harm in trying it out.by the way, there are contraindications in using that firmware patch?
Posted 16 June 2011 - 02:43 PM
ok, thank you
