Still, if you want to program in this lovely programming language, it is quite possible to combine your VB-code with C# drivers! For example, the attached project combines the wonderful LCD-class from http://geekswithblog...id_crystal.aspx with VB.NET.
How to proceed?
Step 1: Create your VB-project
Step 2: Click on File -> Add -> Existing Project
Step 3: Select the C# project and click on the Open-button
Step 4: Right-click on your VB-project in the Solution Explorer window and select "Add Reference"
Step 5: Go to the Projects-tab, select the C# project and click OK
That's all folks!
Now you can use C# drivers in the wonderful world of Visual Basic!
