Still new at all this stuff, but I have encountered a situation where I need to run PWM at 32Khz. Problem is I have no idea how to calculate the correct period and duration to use with SetPulse. If someone can point me in the right direction I would greatly appreciate it.
Ryan
How to Calculate PWM period and duration for known Frequency?
Started by Ryan Mick, Jun 09 2011 08:55 PM
7 replies to this topic
Posted 09 June 2011 - 08:55 PM
Posted 10 June 2011 - 01:31 AM
Someone else will have to help with implementation. PWM runs at a set frequency so you would run at 32kHz. It would require you to change the duty cycle. 32kHz means you would have to create a new pulse every 3.125e-5 seconds. So a 50% duty cycle would have a hi value for half that. Whatever you are connecting with will have some information about what the different duty cycles mean on the that side.
Posted 10 June 2011 - 09:39 PM
From what I have read elsewhere on the forums PWM runs at a default 10 Khz and that changing duty cycle only affects the default value. But from what I read they said you can change the frequency by using the SetPulse method by giving it the appropriate period and duration.
Maybe some info on what I am trying to do will help. I have picked up a barometric sensor HP03 from Futurlec and it requires a 32 Khz clock input. So I really have 2 choices, figure out how to set a PWN line to 32 Khz or use a 32 Khz crystal. Since I am still new to electronic components and not sure how I would wire in a crystal I thought throwing code at it would be easiest at the moment. But to throw code at it I need to know how I can calculate period and duration. If the easy solution is to wire it to a crystal and someone can share the proper way to do so I would be very glad to hear it.
Ryan
Reference:
PWM Demystified
Ryan
Reference:
PWM Demystified
Posted 10 June 2011 - 10:17 PM
So I did some reading. The SetPulse does take a period and duration. So period = 1/frequency, so you can set that. Although 32kHz is 31.25uS, and the SetPulse seems to only take integers. Then the duration would be a fraction of your set period. So if I set the period at 32uS and wanted a duty cycle of 50% I'd set the duration at 16uS.
see:
http://10rem.net/blo...-modulation-pwm
Anyone else want to comment on this?
Hope this helps.
Posted 10 June 2011 - 11:29 PM
/// <summary> /// Set the dutycycle of the 32kHz signal /// </summary> /// <param name="dutyCycle">A value between 0.0f and 100.0f</param> private void SetPwm(float dutyCycle) { var period = (uint)(1000000.0f / 32000.0f + 0.5f); var duration = (uint)(dutyCycle * 0.01f * period + 0.5f); m_pwm.SetPulse(period, duration); }
Unfortunately this will result in a period of 31.25, which when rounded will be 31, or an actual frequency of 32,258.06 Hz.
EDIT: OK I re-read your post, and seems you only need 50% duty cycle. In that case all you need to do is something like:
m_pwm.SetPulse(31, 15);
Once again unfortunately you can't get exactly 32kHz. I wonder how critical it is to be exactly 32kHz.
Posted 13 June 2011 - 04:09 PM
Thanks guys, that is the info I am looking for. I hear an future update to PWM is going to have the ability to set a frequency directly which will make this kind of stuff even easier.
Thanks again,
Ryan
Posted 13 June 2011 - 09:58 PM
I hope these comments helped. If you get the sensor up and running document it in the Wiki, if you can. It would be a good guide.
Posted 13 June 2011 - 10:42 PM
Funny thing is I never noticed the wiki link at the top before. Will do, I am also working with the HH10D humidity which takes some extra steps to get working as well. When it's all working well I will put them both in the wiki.
