Another Analog Input Question
Posted 24 August 2010 - 08:11 PM
Posted 24 August 2010 - 08:40 PM
Hi, I have wired up a sparkfun Triple Axis Accelerometer Breakout ADXL335 to the netduino as follows:
x - PIN_A0
y - PIN_A1
z - PIN_A2
VCC - 3V3 && Aref
GND - Gnd
All works ok when I only try to read a single port, however if I try to read all 3 as detailed below the netduino drops out during the while statement and then I have to do a manual erase of the program via MFDeploy before I can successfully deploy to the device again.
My program is as follows:
namespace accelerometer
// Define our accelerometer inputs
static AnalogInput accX;
static AnalogInput accY;
static AnalogInput accZ;
// Create the Inputs
accX = new AnalogInput(Pins.GPIO_PIN_A0);
accY = new AnalogInput(Pins.GPIO_PIN_A1);
accZ = new AnalogInput(Pins.GPIO_PIN_A2);
// Output the values ???
// When alone works fine
Debug.Print("accX: " + accX.Read().ToString());
// This (multiple) doesn't
// Debug.Print("accX: " + accX.Read().ToString());
// Debug.Print("accY: " + accY.Read().ToString());
// Debug.Print("accZ: " + accZ.Read().ToString());
I have tested the accelerometer via just running the single input code and swapping in the respective wire for x,y,z. The likelihood is that I am missing something obvious due to inexperience etc so with that in mind a few questions:
I have assumed that I can wire in multiple analog inputs which can be read concurrently. Is this correct?
Drawing upon peoples vaster pools of knowledge do I seem to have I wired up the system correctly?
Does the Aref only cater for a single input?
Cheers dyadica
Did you have update the firmware with patch 2, which include a fix regarding multiple analog use ?
Pascal
Posted 24 August 2010 - 08:46 PM
Posted 24 August 2010 - 08:54 PM
Posted 24 August 2010 - 10:13 PM
Posted 16 November 2011 - 03:19 AM
There was a bug in the AnalogInput code. We fixed it in the v4.1.0.2 (patch 2) firmware about a week ago, so it's likely that your Netduino is running older firmware.
Download the firmware update here:
http://forums.netdui...e-v410-patch-2/
Does that fix things up for you?
Is the fix included in update 6? I'm trying a similar hookup with my ADXL335 without much success. I also noticed that all my analog ports read the same value when I have a single potentiometer hooked up to the first Analog pin.
Posted 16 November 2011 - 12:44 PM
Posted 16 November 2011 - 03:21 PM
Hi Driver A,
Yes, this bug was fixed a while ago and the bugfix is included in all recent version of firmware.
Do you have your analog device hooked up to 3.3V, GND, and the analog pin? What happens if you tie all other analog pins to GND (after opening them up as AnalogInputs in code)?
I will try that later today and let you know.
Dan
Posted 17 November 2011 - 03:58 AM
Hi Driver A,
Hi again,
So I've tried two things.
Firstly, I tried a single potentiometer on analog pin 1, grounded the rest of the analog pins and measured all the values. Everything works as expected: pin 1 gives me the voltage provided by the potentiometer, and all the others (2 - 6) give me 0. If I remove the ground from either of them the value is bogus.
Secondly, I tried with the ADXL335:
- VCC -> 3.3V + AREF
- GND -> GND
- X -> A0
- Y -> A1
- Z -> A2
and A3, A4, A5 -> GND
... with the same result as before. The only pin that seems to give me anything useful is Z (A2). The other two give me very low numbers. I measured the voltages between the analog pins and the ground and the results seem to concur with what I'm reading in the software: just over 0 volts on X and Y, and ~2.7 volts on the Z.
I'm starting to think I broke the ADXL, unsure how though. I will take a better look at the specs.
Cheers,
Dan
