I just got my Netduino board and RFID reader, and I wanted to test it out. I used afulki's class to do the reading. However I'm noticing an issue with noise readings. I'll read a badge and the Netduino sends a UDP packet to my computer and it flashes some information. But every once in a while a "tag" flashes up even though no badge came near the reader.
Any suggestions would be appreciated.
TJ
Parallax RFID Reader
Started by ATXcoder, Aug 24 2010 05:24 AM
28 replies to this topic
#21
Posted 01 July 2011 - 07:48 PM
#22
Posted 01 July 2011 - 08:20 PM
Hi Justinius,
which chip is used on the RFID board?
#23
Posted 01 July 2011 - 08:29 PM
There is a PIC 16F627A uController and a EM4095 RFID chip
#24
Posted 02 July 2011 - 11:58 AM
ah too bad, that's not even close to my RFID reader; https://stefan.co/ne...30-rfid-reader/
#25
Posted 05 July 2011 - 07:50 PM
No ideas? Using the class from Afulki I get spurious reads. The solution I think is to do two reads in a short period of time and compare the results. But with the interrupt I'm not sure thats feasible. Any ideas?
#26
Posted 06 July 2011 - 02:43 AM
I think I have a solution. I'm going to add some members variables to the class to preserve a state. On the first triggering it will parse as normal, but set a state variable. Then if the user keeps the card there long enough it will retrigger the event. I'll check the state and if the IDs match I'll certify that its a valid card. I'll post when I get it tested tomorrow.
#27
Posted 06 July 2011 - 11:32 PM
public class ParalaxRFID { private int _readDelay = 1500; private bool _readerEnabled = false; public SerialPort SerialPort { get; set; } public OutputPort RfidControl { get; set; } public delegate void CardReadEventHandler(ParalaxRFID sender, string cardID); public event CardReadEventHandler OnCardRead; public delegate void StatusChangedEventHandler(ParalaxRFID sender, bool readerEnabled); public event StatusChangedEventHandler OnStatusChanged; private byte[] _messageBuffer = new byte[10]; private int _messageCounter = -1; // -1 = waiting for start char, 0 or more means reading message private string _cardID; private int _num_reads = 0; public int ReadDelay { get { return _readDelay; } set { _readDelay = value; } } public bool ReaderEnabled { get { return _readerEnabled; } private set { _readerEnabled = value; if (OnStatusChanged != null) { OnStatusChanged(this, value); } } } public ParalaxRFID(string portName, Cpu.Pin controlPin, bool autoEnable = true) : this(new SerialPort(portName, 2400, Parity.None, 8, StopBits.One), new OutputPort(controlPin, false), autoEnable) { } public ParalaxRFID(SerialPort sPort, OutputPort rfidControl, bool autoEnable = true) { this.SerialPort = sPort; this.RfidControl = rfidControl; SerialPort.WriteTimeout = 1000; SerialPort.Open(); SerialPort.DataReceived += new SerialDataReceivedEventHandler(SerialPort_DataReceived); if (autoEnable) EnableReader(); } public void DisableReader() { RfidControl.Write(true); if (SerialPort.IsOpen) SerialPort.Close(); ReaderEnabled = false; } public void EnableReader() { if (!SerialPort.IsOpen) SerialPort.Open(); RfidControl.Write(false); ReaderEnabled = true; } private void DoReadDelay() { if (ReaderEnabled) { DisableReader(); Thread.Sleep(ReadDelay); EnableReader(); } } void SerialPort_DataReceived(object sender, SerialDataReceivedEventArgs e) { SerialPort sp = (SerialPort)sender; while (sp.BytesToRead > 0) { // temp buff to hold message, byte[] buf = new byte[1]; // Read a single byte from the recv buffer, if (sp.Read(buf, 0, 1) > 0) { // Start of Message? if (buf[0] == '\n') { _messageCounter = 0; } // End of message? else if (buf[0] == '\r') { if (_messageCounter > 9) { String cardID = String.Empty; for (int i = 0; i < 10; i++) { cardID += (char)_messageBuffer[i]; } if (_num_reads == 1 && OnCardRead != null) { _num_reads = 0; if(card_ID == _cardID) OnCardRead(this, cardID); } else if(_num_reads == 0) { _num_reads++; _cardID = cardID; } } _messageCounter = -1; DoReadDelay(); } else // Store it in the global buffer, { if (_messageCounter < 10) { _messageBuffer[_messageCounter++] = buf[0]; } else _messageCounter = -1; } } } } }
I then changed the read delay member to a shorter time span. The user has to hold the card there longer, but it seems to work.
Although I have a question/comment about this solution. When I set the read delay to 100, I get an IndexOutOfRange Exception in the _messageBuffer[_messageCounter++] = buf[0]; line. If I change the read delay to 50, 150, 200, 500 I do not recieve this error. Any ideas?
#28
Posted 27 January 2012 - 05:43 AM
I thought Netduino doesn't support serial communication without an FTDI chip??
#29
