XML-RPC with .net mirco framework - howto ?
Posted 30 May 2011 - 01:11 AM
Posted 31 May 2011 - 12:02 AM
Like I said, I've never done XML-RPC, but that's how I would approach it...
-Valkyrie-MT
Posted 05 December 2011 - 08:59 AM
Hello,
I need to set up a communication from the netduino plus to an existing XML-RPC Service.
More info could be found here: http://www.xmlrpc.com/
I tried to use the wellknown .net implementation from Charles Cook.
http://www.cookcompu...blog/index.html
Unfortunatly the build failed, it seems that the implementation from Charles Cook doesn´t run on .net MF.
The same code works fine in a console application.
Has somebody experience with XML-RPC implementations on .net MF ?
Thanks for your support
Andy
Did you get a solution for this? If so can you please share your experiance?
You may probably like to see my work Kaushik SPOT Services for .NET Micro Framework. If RPC did not work for you, you may see how this fits in to what you want.
