Bring 30 amp signal down to 16ma for input
Posted 23 May 2011 - 04:37 AM
Posted 23 May 2011 - 05:31 AM
Posted 23 May 2011 - 02:28 PM
Posted 23 May 2011 - 03:17 PM
Posted 23 May 2011 - 03:48 PM
Posted 23 May 2011 - 05:10 PM
Posted 23 May 2011 - 05:42 PM
Posted 23 May 2011 - 06:09 PM
Current clamp?I am new to the world of electronics and I want to tap into a signal to tell when something is on or off. When the external switch is on the current is 30amp and I want to sample it using netduino. I am thinking that using a relay and a resistor will be the best bet but I'm not really sure what to look for in one to be sure I don't break the netduino. Any tips would be great
Posted 23 May 2011 - 06:11 PM
Current clamp?
That's actually a good idea, how would I connect this to netduino though?
Posted 23 May 2011 - 07:06 PM
There is an energy monitoring project for the Arduino which you could use that as a starting point. Your original post suggests you just want to detect on or off. I'd think about calibrating the clamp and determining the on / off output readings. You could then use either the analog ports or if you wanted digital then maybe a transistor as a switch.That's actually a good idea, how would I connect this to netduino though?
Hope this helps,
Edit: Remember to take into consideration that Arduino is 5V but Netduion is 3.3V.
Posted 24 May 2011 - 03:40 AM
Stop guys: the current clamp needs AC current!Current clamp?
That's the way I asked for the kind of current...
The easier way is using a shunt.
Let's say you break the circuit and insert a resistor having a very small value in series.
Take a look at the schematic attached.
I supposed that:
the common ground of the Netduino can be connected to the battery negative wire;
the shunt (10milli Ohm resistor) is connected as the schematic.
At this point you may use an analog input to measure the voltage on point "A", and the circuit rightward this point could be discarded. Otherwise you may consider that additional circuit to use a digital input.
Note that 30Amps flowing through a 10milli Ohm shunt produces a voltage drop of about 0.3V. It means that your LOAD will be powered at 12-0.3 = 11.7V.
Posted 24 May 2011 - 06:30 AM
Good catch.Stop guys: the current clamp needs AC current!
BTW - Would it be advisable to use opto isolation?
Posted 24 May 2011 - 06:45 AM
Absolutely.BTW - Would it be advisable to use opto isolation?
However the circuit will turn more complex, although I'd prefer any kind of insulation at all.
PS: "isolation" or "insulation"?
Posted 24 May 2011 - 06:48 AM
How about using (only) the optoisolator in parallel with the load? It will output digital signal according to the internal LED state, i.e. when the load is switched on/off.However the circuit will turn more complex, although I'd prefer any kind of insulation at all.
Posted 24 May 2011 - 07:07 AM
I asked it about yet, but it seems that's not possible for the 30A load. Take a look above.How about using (only) the optoisolator in parallel with the load? It will output digital signal according to the internal LED state, i.e. when the load is switched on/off.
Posted 24 May 2011 - 07:19 AM
Could you be more specific, please? Why it is not possible to add the optoisolator in parallel with the load?I asked it about yet, but it seems that's not possible for the 30A load. Take a look above.
Posted 24 May 2011 - 07:27 AM
#19
Posted 24 May 2011 - 07:39 AM
I see, I missed that post, thanks. Unfortunately, the 'diagram' seems to be no longer available.@CW2: I don't know why it is not possible. I asked whether it is possible to monitor the voltage across the load, but (4th post) the poster say's not possible.
