I have a couple boxes full of HHP IT3800 Barcode Scanners with the PS/2 connectors on them.
The PS/2 cable is connected to the unit via a 10 pin modular.
I would like to be able to read a barcode and dump it to the debug screen.
Once I have this figured out then I will dump the read to the Nokia 3110 LCD screen and possibly log it to the SD Card.
I have figured out Power, GND, Data, & Clock lines for the scanner.
My issue is I cannot find any wiring or code examples on how to read barcodes.
Do I want to connect the data pin on the scanner to an Analog or Digital input?
Where do I connect the clock line? Pin 13 on the netduino?
Started by K0demonkey, May 20 2011 04:08 PM
Posted 20 May 2011 - 05:28 PM
I don't think you need to worry about reading the barcode as such. If the reader had a PS2 connector on it then it will be highly likely that it will act as a keyboard. I'd be looking for keyboard drivers.
Hope this helps,
Posted 20 May 2011 - 06:49 PM
Any chance someone could attempt porting this PS2Keyboard Library to Netduino?
Posted 20 May 2011 - 07:38 PM
Forgot to mention, assuming the scanner has two PS2 connections, one female, one male, you can verify this by connecting the scanner to Notepad.
Connect the Male connector to a PC, connect a PS2 keyboard to the female connector.
Start the PC and open notepad. Make sure notepad has focus.
Grab something with a barcode - say a book and scan the barcode.
You should see the barcode decoded and appearing in notepad.
