Communication between 2 or more duino's
Posted 23 August 2010 - 07:47 PM
Posted 23 August 2010 - 07:54 PM
Any thoughts experiances on connecting 2 or more netduino's over a 5 meter distance?
I have no idea, and was thinking of an ethernet shield, is that a good idea? Is there something better/cheaper?
Just use a XBee wireless. It's straight serial comm through the UART so it's easy.
Posted 23 August 2010 - 07:57 PM
Thanks but,
forgot to mention: I want it te be wired, not wireless. And I want to connect 3 or more..
Posted 23 August 2010 - 08:53 PM
What topology?And I want to connect 3 or more..
Posted 23 August 2010 - 09:31 PM
What topology?
3 or more you've got a couple choices - you can use I2C to do it and give each a different address or you can use ethernet.
Personally, as a network engineer I'd say ethernet but there aren't any ethernet drivers for the netduino (yet!).
Posted 23 August 2010 - 09:39 PM
The I2C on the ARM7X chip is master-only. We'll see what we can do on speeding up Ethernet support...
Posted 23 August 2010 - 09:41 PM
+1 for Ethernet.
It's seems that I2C .net MF implementation (like SPI) is always master. So, we cannot use I2C to cummunicate between 2 Netduino(s). Or we need to write another driver.
And I2C is very slow for that distance.
Pascal
Posted 23 August 2010 - 09:45 PM
Woops - I remember seeing that but forgot.
Ethernet is your best option then if you want wired communication.
Personally XBee is a great option - inexpensive, mesh topology, wireless, variety of ranges and best of all - SIMPLE.
But again, as a network engineer I'd love to be able to send/receive TCP and UDP from my netduino. Come on Chris - get cracking!
Posted 23 August 2010 - 09:49 PM
I2C master-only is a limitation of ARM7X or .NET micro framework ?
Perhaps I'm wrong, but when I read the datasheet, it's seems that the ATMEL used on netduino support both mode, no ?
Pascal
Posted 23 August 2010 - 09:56 PM
From the AT91SAM7X512 datasheet:
One Two-wire Interface (TWI)
– Master Mode Support Only, All Two-wire Atmel EEPROMs and I2C Compatible Devices Supported
A driver for SPI slave mode could be written, but I2C slave would require a "bit banged driver."
Posted 23 August 2010 - 09:59 PM
Thanks for that clarification
Pascal
Posted 24 August 2010 - 06:18 AM
That would be realy cool. Would even do greater distances and could use a switch for connecting them..
Posted 24 August 2010 - 10:40 AM
In the meantime I recommend reading the "Making Things Talk" book that dicusses many other communication technologies.
http://oreilly.com/c...g/9780596510510
Maybe it will give you some ideas. In any case let us know what you came up with.
