Power through vIn pin?
9 replies to this topic
#1 Rod Lopez
Rod Lopez
  • 33 posts
  • LocationSweden
Posted 10 May 2011 - 08:34 AM
Can I power the Netduino using unregulated 7.5-12 volts though the vIn pin in the board? as in... instead of using the power connector If so.. what's the maximum power I can drain? (I have a few 3.3 and 5v devices connected to the Netduino)
#2 Mario Vernari
Posted 10 May 2011 - 08:47 AM
According to the schematic, you can. What kind of power are you meaning? The Vin itself or the regulated 5 and/or 3.3V? Cheers
#3 Rod Lopez
Rod Lopez
  • 33 posts
  • LocationSweden
Posted 10 May 2011 - 08:59 AM
I mean the Vin, I would hope not to toast the pin or its connections, right now I am peaking at around 150mA when all servo and display hell breaks loose :) So what I would like to know is if 300mA would be okay to take through the Vin.
#4 Stefan
Stefan
    Moderator
  • 1965 posts
Posted 10 May 2011 - 09:04 AM
I connected a 9V battery and another 12V source to Vin without any problems. It's directly connected to the power socket on the netduino.
#5 CW2
Posted 10 May 2011 - 10:17 AM
Yep, the on-board regulators can handle up to 800 mA, then it depends on the power supply you are using.
#6 Mario Vernari
Posted 10 May 2011 - 11:39 AM
CW2 is right: if you are pulling energy from the regulated +5V (or +3.3V), then you have a limit. That limit is overall thermal: maybe you may pull even more than 800mA by using a low voltage supply as Vin. Probably you may exceed a little for peaks. If you mean to power the board with an external supply, then pull out (unregulated) power from the Vin pin, I think you may reach even 2A or so. Cheers
#7 Rod Lopez
Rod Lopez
  • 33 posts
  • LocationSweden
Posted 10 May 2011 - 01:03 PM
I'll use Vin as input then, there's one tiny detail left though... the switching between Vin and USB for power, is it mechanical or electronic?
#8 Mario Vernari
Posted 10 May 2011 - 01:08 PM
It's an electronic switch: as the Vin goes live, a mosfet opens the USB power circuit. Refers to the schematic, upper-left corner, U1 and Q4... Cheers
#9 Rod Lopez
Rod Lopez
  • 33 posts
  • LocationSweden
Posted 10 May 2011 - 01:14 PM
so I thought, my EE skills are a tad rusty, so didn't want to risk it :) Thanks!
#10 CW2
Posted 10 May 2011 - 01:18 PM
Please note in case of USB power Netduino is configured to draw max. 280 mA (but again it depends on the hub).
Edit: To be precise, Netduino reports max. power consumption of 280 mA in the USB configuration descriptor.
Edited by CW2, 10 May 2011 - 01:22 PM.
