How to manual read/write internal flash?
#21
Posted 16 May 2011 - 12:22 PM
#22
Posted 16 May 2011 - 01:06 PM
#23
Posted 16 May 2011 - 01:24 PM
They still are limited to 10k cycles right?Just FYI, Storage A/B are just placeholders for now. The plan is to replace them with "simple storage" sectors in the .NET MF 4.2 firmware update.
#24
Posted 16 May 2011 - 01:25 PM
So right now Storage A/B are not used for anything by MF or the netduino firmware?
Do you know if it's possible to keep data stored in Storage A/B when deploying/debugging via Visual Studio? It's very annoying that my data is erased every time I start the debugger (app code is deployed).
#25
Posted 16 May 2011 - 01:27 PM
Correct. For frequently-rewritten data, an SD card or EEPROM is your best bet. Flash is best for permanent storage of occasionally-changed data.
Posted 16 May 2011 - 01:28 PM
There is no code-accessible persistent storage built into the microcontroller on Netduino today. You can use the MicroSD feature of the Netduino Plus for that...or hook up an external SD card or EEPROM to your Netduino/Netduino Mini if desired.So right now Storage A/B are not used for anything by MF or the netduino firmware?
Posted 16 May 2011 - 01:31 PM
I think that's a very important footnote that should be mentioned with the feature to write to flashCorrect. For frequently-rewritten data, an SD card or EEPROM is your best bet. Flash is best for permanent storage of occasionally-changed data.
But I'm glad to see that it will become possible since it's the cheapest solution to store a few config values!
#28
Posted 18 April 2012 - 12:15 PM
Hi Klop,
You can embed data inside your app if you want as well. .NET MF supports resources.
.NET MF 4.2 (beta coming by summer) includes a new "simple storage" mechanism for storing data on-chip. We'll be embracing this in the Netduino 4.2 firmware to enable you to read/write data from your Netduino app as well.
Is this ability currently available in 4.2 RC4? If so, are there any examples of how to do this?
I'm thinking this may be a good way for me to have a Unique Identifier on each Netduino Board.
#29
Posted 18 April 2012 - 08:27 PM
#30
Posted 18 April 2012 - 08:43 PM
Hi Dave,
Simple Storage didn't make it onto Netduino Plus. Between the amount of flash required for the 16KB of storage blocks plus the flash needed for a non-standardized set of classes to access it...we decided that it was best to leave the flash to your Netduino Plus app instead.
That said, you can use the MAC as a unique ID on your board.
In the end we are not planning on having Ethernet capabilities. We will likely be using a standard ND board with an SD card board. Sad to hear this didn't make 4.2
#31
Posted 18 April 2012 - 08:51 PM
#32
Posted 13 December 2012 - 03:23 PM
#33
Posted 13 December 2012 - 04:43 PM
Can you give me more details as to what you're looking for? The general plan right now is to use the MAC address as a unique ID on Netduino Plus 2. We're planning a future firmware update which can burn a default MAC address into OTP so it survives re-flashing.Any Progress towards getting this into Netduino Plus 2? It would be great to be able to assign a Unique ID to the boards that isn't the MAC ID.
Posted 13 December 2012 - 07:21 PM
Hi Dave,
This was on the addition of the Simple Storage option to read/write to the flash. My thought was to use it for a unique ID for the Netduino's and one that couldn't be deleted with loss of the network settings.
