Force Sensor - Easy Example and Special Class
#1 Omar (OZ)
Omar (OZ)
  • 564 posts
Posted 26 April 2011 - 01:02 AM
I know some people wanted more analog examples and here it is! This was much easier than I thought, force sensors are not that complicated. These are called force sensitive resistors as well. Here is is:
*Always use a resistor! Dont imitate my bad habit!
Attached File  force sensor schem.PNG   103.22KB   179 downloads
Attached File  force sensor schem 2.PNG   41.62KB   188 downloads
Attached File  force sensor test.jpg   790.22KB   138 downloads
Magic! Oh right the code....
            AnalogInput input = new AnalogInput(Pins.GPIO_PIN_A0);
            PWM led = new PWM(Pins.GPIO_PIN_D10);
            input.SetRange(0, 100);
                led.SetDutyCycle((uint)input.Read());
                Thread.Sleep(1);
To enable event firing use this class I created [since analog port doesnt have built in event stuff]
namespace Sensors
    public delegate void ChangedValue(int oldValue, int newValue, DateTime time);
    public class Force
        public event ChangedValue ValueChanged;
        Thread updater;
        AnalogInput input;
        int oldVal = -1;
        public int ignoreChangeLessThan = 0;
        public Force(Cpu.Pin analogPin)
            input = new AnalogInput(analogPin);
        public void SetRange(int min, int max)
            input.SetRange(min, max);
        public int Read()
            return input.Read();
        public void UpdateConstantly(bool update)
            if (update)
                updater = new Thread(new ThreadStart(Update));
                oldVal = input.Read();
                updater.Start();
            else
                if (updater != null)
                    updater.Suspend();
        private void Update()
            while (updater.IsAlive)        // as long as we havent stoped the thread...
                int newVal = input.Read(); // get the current value
                if ((newVal < oldVal - ignoreChangeLessThan) || (newVal > oldVal + ignoreChangeLessThan))
                    if(ValueChanged != null)
                        ValueChanged(oldVal, newVal, DateTime.Now); // if the value has changed more than the filter value then fire the event
                    oldVal = newVal;                                // now this is the new value to base a change off of.
Use:
static Force f = new Force(Pins.GPIO_PIN_A0);
            f.ValueChanged += new ChangedValue(f_ValueChanged);
            f.UpdateConstantly(true);
            Thread.Sleep(Timeout.Infinite); // just keep on waiting... forever
        static void f_ValueChanged(int oldValue, int newValue, DateTime time)
            Debug.Print("Old: " + oldValue + " || New: " + newValue);
            //f.UpdateConstantly(false); // stop  the updating using that line
When ignoreChangeLessThan is 0 you'll get tons of fires, i suggest a setting of 3 depending on your range or sensor you'll have to fiddle with values.
Sample output (tiny part of it) with ignoreChangeLessThan being 0:
Old: 810 || New: 823
Old: 823 || New: 836
Old: 836 || New: 847
Old: 847 || New: 855
Old: 855 || New: 865
Old: 865 || New: 873
Old: 873 || New: 878
Old: 878 || New: 886
Old: 886 || New: 892
Old: 892 || New: 899
Old: 899 || New: 903
Old: 903 || New: 907
Old: 907 || New: 911
:D enjoy
#2 ULight.Me
ULight.Me
  • 12 posts
  • LocationMilton, Ontario
Posted 22 June 2011 - 01:44 AM
                Thread.Sleep(1);
See easy! :D enjoy
How would you do this using event handling and interrupt port?
#3 Omar (OZ)
Omar (OZ)
  • 564 posts
Posted 22 June 2011 - 03:54 AM
It is an analog pin so it doesnt have an event structure built in... I'll have a class posted up there in a sec that will allow you to do this.
Update: class is up there, let me know if it helps
#4 u1054371
u1054371
Posted 28 June 2011 - 09:20 AM
Can you upload the source code for this project? Thanks for all, good job.
#5 Omar (OZ)
Omar (OZ)
  • 564 posts
Posted 28 June 2011 - 07:43 PM
I attached a zip of the project.
