I am scared to try and brick my netduino plus :
I want to use the /Reset pin on my netduino plus to reset the device. Do I need to connect it to +5V to reset or Ground (does the "/" before reset stand voor "inverted" ?). And do I need to add a resistor ?
Sander.
Resetting on /Reset pin
Started by sanders, Apr 16 2011 11:14 AM
Posted 16 April 2011 - 11:14 AM
Posted 16 April 2011 - 02:18 PM
I don't know how to reset it but the netduino is 3.3V not 5V !Do I need to connect it to +5V to reset
Started with C in 1985, moved to Vb3 ... to vb6 and stopped. Now started with .Net and learning C# and VB.net and wishing VB.net was on MF !
Posted 16 April 2011 - 02:43 PM
Yes, "/" stands for "inverted" (resp. active low), so you'd need to connect the /RESET pin to ground. If you mean resistor connected in series (current limiting), it is not necessary.I want to use the /Reset pin on my netduino plus to reset the device. Do I need to connect it to +5V to reset or Ground (does the "/" before reset stand voor "inverted" ?). And do I need to add a resistor ?
- Chris Walker and sanders like this
Posted 17 April 2011 - 11:53 AM
Thanks all !
