String.format
#1 Rod Lopez
Rod Lopez
  • 33 posts
  • LocationSweden
Posted 13 April 2011 - 12:26 PM
Hi there,
I am having a very simple issue, I am trying to write a few values to a 16x2 LCD, the values are, originally floats. I need to be able to see the whole set of info in a single glance.
The issue is that, by default, I end up printing too much (the number plus eight digits of precision), so my result doesn't fit on the screen at all.
My code looks like this:
	float A = 0, V = 0;
	PowerSampling.GetPower(ref V, ref A);
	Write("V " +  V + " A:" + A + " W:" + A * V);
...and the code I am trying to replicate (I am porting this from an Arduino) looks like this:
	float A, V;
	PowerSampling.GetPower(V, A);
	lcd << "V" << _FLOAT(V, 1) << " A" << _FLOAT(A,2) << " W" << _FLOAT(V * A,1);
I was intending to use String.Format but that doesn't seem to be supported... how can it be done?
#2 Rod Lopez
Rod Lopez
  • 33 posts
  • LocationSweden
Posted 13 April 2011 - 01:35 PM
In case anybody else has similar issues the solution is as simple as this:
Write("V " + V.ToString("F1") + " A:" + A.ToString("F2") + " W:" + (A * V).ToString("F1"));
...the funny thing is that ToString sometimes seems to return the value and sometimes the name of the type, that's why I didn't try it before. :)
#3 Mario Vernari
Posted 13 April 2011 - 02:15 PM
No better than this:
static string Format(double v, int n)
            const string padding = "0000";
            double vr = Math.Round(v, n);
            string fmt = vr.ToString();
            int pos = fmt.IndexOf('.');
            if (pos >= 0)
                int ndig = fmt.Length - pos - 1;
                if (ndig < n)
                    return fmt + padding.Substring(0, n - ndig);
                else
                    return fmt.Substring(0, fmt.Length - ndig + n);
            else
                return fmt + "." + padding.Substring(0, n);
NOTE: does not works when the numbers needs an exponent to be formatted (e.g. 1E20)
Anyone can adjust this function?
Was not so easy!
