My first Robot Project
#1 Asymptot
Asymptot
  • 19 posts
Posted 08 April 2011 - 04:40 PM
I finally completted my robot project.
It's nothing big. It doesn't know where it is going, but it knows an obstacle when it sees one.
I got those parts :
- 2 motors & wheels
- 1 IR range detector
- 1 DFRobot shield
- 1 disc-shaped Popolu chassi
- 1 stabilizing ball
I wrote a specific reusable class for Motors. It is not perfect, since it assumes I am using a DFRobot shield, and the speed is hardcoded (even though I prepared a variable speed for the future.
Here is the class :
namespace Robot_Tests
    enum Motors
        M1,
        M2
    class MotorShield
        public const Cpu.Pin M1 = Pins.GPIO_PIN_D7;
        public const Cpu.Pin E1 = Pins.GPIO_PIN_D6;
        public const Cpu.Pin M2 = Pins.GPIO_PIN_D4;
        public const Cpu.Pin E2 = Pins.GPIO_PIN_D5;
        /// <summary>
        /// Represents the motor's speed
        /// </summary>
        private int _speed;
        /// <summary>
        /// </summary>
        public int Speed
            get
                return _speed;
            set
                _speed = value;
        /// <summary>
        /// Represents the left Motor
        /// regardless the Pin chosen on the Shield
        /// </summary>
        private Motor _leftMotor = new Motor();
        /// <summary>
        ///Represents the right Motor
        /// </summary>
        private Motor _rightMotor = new Motor();
        public MotorShield()
            //Sets the motors to a default value
            SetMotors(Motors.M1, Motors.M1);
        /// <summary>
        /// Set which motor is right and which motor is left.
        /// </summary>
        /// <param name="MLeft">Motor used as the left Motor</param>
        /// <param name="MRight">Motor used as the right Motor</param>
        private void SetMotors(Motors MLeft, Motors MRight)
            if (MLeft == MRight || MLeft == Motors.M1)
                //Sets a default case in case same motor is chosen twice
                //Sets the case where M1 is left and M2 is right
                _leftMotor.E = new PWM(E1);
                _leftMotor.M = new OutputPort(M1, true);
                _rightMotor.E = new PWM(E2);
                _rightMotor.M = new OutputPort(M2, true);
            else
                //Sets the remainning case : M1 is right and M2 is left
                _rightMotor.E = new PWM(E1);
                _rightMotor.M = new OutputPort(M1, true);
                _leftMotor.E = new PWM(E2);
                _leftMotor.M = new OutputPort(M2, true);
        public void MoveForward()
            _leftMotor.M.Write(true);
            _leftMotor.E.SetDutyCycle(100);
            _rightMotor.M.Write(true);
            _rightMotor.E.SetDutyCycle(100);
        public void MoveBackward()
            _leftMotor.M.Write(false);
            _leftMotor.E.SetDutyCycle(50);
            _rightMotor.M.Write(false);
            _rightMotor.E.SetDutyCycle(50);
        public void TurnLeft()
        public void TurnRight()
        public void SetSpeed(uint iSpeed)
            _rightMotor.setSpeed(iSpeed);
            _leftMotor.setSpeed(iSpeed);
    /// <summary>
    /// This class represents a single Motor
    /// This is designed for the classic Netduino and will use the
    /// Netduino classes and conventions
    /// </summary>
    class Motor
        #region Properties
        /// <summary>
        /// E represtens the PWM pin chosen for this Motor speed control
        /// (Conventionnally represented by the letter "E").
        /// </summary>
        private PWM _E;
        public PWM E
            get
                return _E;
            set
                _E = value;
        /// <summary>
        /// M represents the digital pin chosen for this Motor direction control
        /// </summary>
        private OutputPort _M;
        public OutputPort M
            get
                return _M;
            set
                _M = value;
        private int _speed;
        public int Speed
            get
                return _speed;
            set
                _speed = value;
        //private OutputPort SpeedPort = new OutputPort(
        #endregion
        #region Constructors
        public Motor()
        public Motor(PWM pwm, OutputPort OutP)
            E = pwm;
            M = OutP;
        #endregion
        public void setSpeed(uint iSpeed)
            if (iSpeed > 100)
                iSpeed = 100;
            E.SetDutyCycle(iSpeed);
I also coded an IR Range detector class, but it's nothing new.
Here is the end result :
http://www.youtube.com/watch?v=ercJ2oK5O1I
That's it.
Now I achieved this simple thing, what is the logical next step? Giving it a sense of direction? Making its current direction better by ensuring both motors really run at the same speed? Any suggestion to make it better?
Asymptot
#2 Dan Morphis
Dan Morphis
  • 188 posts
Posted 08 April 2011 - 05:20 PM
Great work! I do have a few recommendations though. I don't know if you've seen the new auto-property support thats in C# v3, but it will turn this:
        /// <summary>
        /// </summary>
        private int _speed;
        /// <summary>
        /// </summary>
        public int Speed
            get
                return _speed;
            set
                _speed = value;
into this:
        /// <summary>
        /// </summary>
        public int Speed { get; set; }
Under the hood the compiler will create the backing field, but the code is now visually smaller. I've done this in a lot of the code I've written and it helps me tremendously by reducing the first glance visual complexity of my code.
#3 Corey Kosak
Corey Kosak
  • 276 posts
  • LocationHoboken, NJ
Posted 09 April 2011 - 02:01 AM
AHAAHAHAHAHAH I love that crazy little robot. It's so cute (and hyper!)
#4 Nevyn
Nevyn
  • 1072 posts
  • LocationNorth Yorkshire, UK
Posted 09 April 2011 - 05:51 AM
You might want to look at the code generated as I think the compiler generates fairly long names for the backing variable which bloats the assemblies a little. If space becomes tight then using your own backing variable may give smaller code. See this thread and posting ##2 by CW2
Regards
#5 Asymptot
Asymptot
  • 19 posts
Posted 09 April 2011 - 03:13 PM
Thank you for the info. I wasn't familiar with that. Now, I would like to improve the project. I think I will try to make my motor class more generic for a start. Then, I noticed the motors don't run at the same speed, even when set at the same PWM. Is there a way to correct that? I dug a bit and saw devices that counted the number of rotation, but I'm not too familiar with that. Any sugestion as what i could add or change to the project will be welcome.
