Out of memory issues
5 replies to this topic
#1 Rod Lopez
Rod Lopez
  • 33 posts
  • LocationSweden
Posted 29 March 2011 - 11:32 PM
Hi there,
This is my first post here, so please let me know if I am posting in the wrong place :)
So, as to the issue...
I have a setup where I am using one of the Netduino COMs as serial interface to an external chip (an IMU), communication works, and everything is fine and dandy (a.k.a I get my data through the serial), but I eventually (pretty much at predictable intervals) get an 'Out of Memory' error.
I honestly thought that moving to a managed framework meant that you didn't have to care about your memory anymore, is that true? do I need to release / dispatch memory blocks somehow? Do I need to manually invoke the garbage collector?
Could you give a look to the code and tell me if I am doing something terribly wrong?
thanks!!
-rod
IMUSerial = new SerialPort("COM1", 9600, Parity.None, 8, StopBits.One);
IMUSerial.DataReceived += new SerialDataReceivedEventHandler(IMUSerial_DataReceived);
IMUSerial.Open();
//write IMU code
Debug.Print("Serial is " + (IMUSerial.IsOpen? "open" : "not opened"));
byte[] pip = System.Text.Encoding.UTF8.GetBytes("r");
Debug.GC(true);
	IMUSerial.Write(pip, 0, 1);
	Thread.Sleep(100);
static void IMUSerial_DataReceived(object sender, SerialDataReceivedEventArgs e)
	byte[] buffer = new byte[10];
	IMUSerial.Read(buffer, 0, 10);
	String message = new String(System.Text.Encoding.UTF8.GetChars(buffer));
	Debug.Print(message);
#2 Mario Vernari
Posted 30 March 2011 - 03:15 AM
About the memory automatic deallocation, by coming into the beautiful world of the managed code, you're in the heaven. The garbage collector do it for you, at least for the most common objects. There are some cases where you must deallocate manually an object, simply because is better having a deterministic destroy, instead waiting an unknown time for the GC.
Such a cases are, for example, sockets, files, input/output ports and others related with the physical layer.
If you meant "forget any problem of memory", that's true on a pc, having Gigs of ram. Here you have a bunch of Kib, so it is very common to see an exception for running out of memory. However the managed code eats much more ram than an equivalent native application.
I don't see anything strange on your code.
The only issue you might have is about the serial incoming data rating. 9600 bps aren't an high speed, but if the incoming bytes are many more than the 10-byte buffer, probably the code is not able to empty the internal buffer.
As far I can see, your code sends a byte every 100ms, but how many bytes should receive within the same timeframe?
#3 demonGeek
demonGeek
  • 42 posts
  • LocationCanada
Posted 30 March 2011 - 05:12 AM
IMUSerial.Open();
//write IMU code
Debug.GC(true);
	Thread.Sleep(100);
What happens if you move the buffer array up to the class level rather than creating a new instance each time the event fires?
#4 Rod Lopez
Rod Lopez
  • 33 posts
  • LocationSweden
Posted 30 March 2011 - 06:24 AM
I get more or less the same result, it might take a bit longer (it is hard to say) but still runs out of memory at aprox the same pace.
I am pretty sure I am getting much more data than what I am consuming -through serialport.read-. I assumed it would be stored in the serial chip's memory and when full it would just drop new data. I'd make sense that, if an internal buffer expands with arriving data it would end up too big... I'll give that a shot and report back
#5 demonGeek
demonGeek
  • 42 posts
  • LocationCanada
Posted 30 March 2011 - 06:41 AM
Try hooking the ErrorReceived event on the SerialPort and see if that provides more information. If you are overflowing the internal buffer it will generate an exception with the event type of RXOver.
#6 Rod Lopez
Rod Lopez
  • 33 posts
  • LocationSweden
Posted 11 April 2011 - 08:24 PM
It seems like it was as Mario suspected, if all the incoming data is not consumed with a read() call it'll just accumulate and start consuming RAM, until it runs out. I connected a callback to RXOver but never got called, I'll get back if I can get the experiment in the right setup again (you know how it when you need to break some things in order to fix others :)
