Multiple devices on 1 SPI interface
7 replies to this topic
#1 Luc Wuyts
Luc Wuyts
  • 4 posts
  • LocationBelgium, Antwerp, Merksem
Posted 27 March 2011 - 08:22 PM
There doesn't seem to be support for multiple SPI devices on the same SPI interface in this framework.
It is possible to do your own CS (chip select) managing, but i prefer the way the SPI class manages this.
So i've made a little factory for making it easy to switch between spi devices.
Use:
byte spiIdDisplay = SpiFactory.AddConfig(new SPI.Configuration(PIN_LCD_CS
                                                  , false
                                                  , 0
                                                  , 0
                                                  , false
                                                  , true
                                                  , 10000
                                                  , SPI.SPI_module.SPI1
        byte spiIdTouch = SpiFactory.AddConfig(
                                                new SPI.Configuration(PIN_TOUCH_CS
                                                  , false
                                                  , 1
                                                  , 1
                                                  , false
                                                  , true
                                                  , 590
and when you want to use a SPI device:
   SPI spi = SpiFactory.GetSPI( spiIdTouch );
/// <summary>
    /// De SPI interface kan meerdere devices aansturen, maar het MF heeft hiervoor geen voorziening.
    /// Ik kies ervoor om verschillende configuraties te gebruiken, en het SPI object telkens te herconfigureren.
    /// Static class gebruikt omdat dit vermoedelijk minder ruimte inneemt dan een Singleton
    /// </summary>
    public static class SpiFactory
        static ArrayList Configurations = new ArrayList();
        static SPI currentSPI = null;
        // Er zullen nooit 256 devices zijn !
        static byte currentId = 0xFF;
        /// <summary>
        /// de ID van de configuratie wordt teruggegeven, zodat dit later
        /// gebruikt kan worden om een nieuw SPI object te configureren.
        /// </summary>
        public static byte AddConfig( SPI.Configuration  config )
            Configurations.Add(config);
            return (byte)(Configurations.Count - 1);
        public static SPI GetSPI(byte spiId)
            if (currentId == spiId)
                return currentSPI;
            if (currentSPI != null)
                currentSPI.Dispose();
            SPI.Configuration config = (SPI.Configuration)Configurations[spiId];
            currentSPI = new SPI(config);
            currentId = spiId;
            return currentSPI;
#2 demonGeek
demonGeek
  • 42 posts
  • LocationCanada
Posted 27 March 2011 - 09:38 PM
The SPI class represents the master device (the Netduino).
Each slave device on the SPI bus is represented by a separate SPI.Configuration and since you can only have one active device at a time, you simply need to switch the configuration when you want to select a different device:
SPI.Configuration slaveDevice1 = new SPI.Configuration(Pins.GPIO_PIN_D10, false, 0, 0, true, true, 500, SPI_Devices.SPI1);
SPI.Configuration slaveDevice2 = new SPI.Configuration(Pins.GPIO_PIN_D9, false, 0, 0, true, true, 500, SPI_Devices.SPI1);
SPI spi = new SPI(slaveDevice1);
spi.Config = slaveDevice2;
I think that the NETMF terminology is a bit confusing in this regard. I would have preferred something like SPI.SlaveConfiguration which makes the relationship a bit clearer. It would also have been nice to have a Configuration collection within the SPI class itself.
- Adam
#3 Stefan
Stefan
    Moderator
  • 1965 posts
Posted 28 March 2011 - 10:45 AM
The SPI classes in .NETMF are indeed a bit confusing, I wrote my own (slightly different) MultiSPI class in which I took the SS-pin in my own hands as well. Lets hope it will be implemented better in .NETMF 4.2. By the way, nice to read the Dutch comments ;) I normally write my comments in English, but that's also because my code will be available for the general public and Dutch isn't a common language (anymore).
#4 hanzibal
hanzibal
  • 1287 posts
  • LocationSweden
Posted 28 March 2011 - 01:46 PM
I have some really bad experience with programmatic CS (chip select) management, it seemed to cause small sporadic errors in data that was hard to track down. I reverted to firmware functionality for CS wich requires multiple SPI.Configuation instances to swtich between. Btw, I'm a Swede and find Dutch writing quite understandable, when spoken I can't really cope though :) The Borers (ancient Dutch people I think) sailed the world and so for instance, Afrikaans is practically Dutch. If I recall correctly, the famous Table Mountain in Cape Town Soutch Africa is called "Taffelberge" in Afrikaans.
#5 Mario Vernari
Posted 28 March 2011 - 02:06 PM
*** OFF TOPIC ***
Btw, I'm a Swede and find Dutch writing quite understandable, when spoken I can't really cope though The Borers (ancient Dutch people I think) sailed the world and so for instance, Afrikaans is practically Dutch. If I recall correctly, the famous Table Mountin in Cape Town Soutch Africa is called "Taffelberge" in Afrikaans.
I am italian, I have learn german and I am using english for my job, but I have hard time reading dutch. However I was in Holland years ago and I loved it so much! I never been in Sweden, though.
I guess we should use english-american for world-wide communications.
*** OFF TOPIC ***
#6 Stefan
Stefan
    Moderator
  • 1965 posts
Posted 28 March 2011 - 02:07 PM
True that. I know a bit Swedish as well. Went to Stockholm and Gävle once. But this is getting offtopic ;) Indeed if the firmware supports multiple SPI devices well, that should be the best way to handle things. I just hope .NETMF 4.2 makes it more clear/easier to understand then it currently is.
#7 Mario Vernari
Posted 28 March 2011 - 02:21 PM
Yep: I am seriously thinking that the first real firmware/framework could be the 4.2. At the moment we have more problems than benefits.
OK, no more comments on that way on this thread.
#8 Luc Wuyts
Luc Wuyts
  • 4 posts
Posted 02 April 2011 - 07:24 AM
I wrote this originally for my own use, and since this is very easy to understand, i didn't think it would be nessecary to translate it first.
I think i'll add some object to this class, wich can be used to lock() and prevent other threads from using the spi bus while busy.
