Running out of memory
Posted 18 March 2011 - 04:06 PM
Posted 18 March 2011 - 06:58 PM
Posted 18 March 2011 - 09:04 PM
Posted 18 March 2011 - 09:47 PM
Posted 18 March 2011 - 09:53 PM
Thanks for the tips guys, I'll have a play around with sockets tomorrow and see what I can come up with.
I'm on a fairly tight schedule with this so dont really have time to mess about with an ethernet shield but from what I've seen the next step up hardware wise seems to be the FEZ cobra which is a monster compared to the netduino!
Hi Calum,
If you're going the non-open-source route, check out Device Solutions' Tahoe II board as well. We've generally had good luck with their hardware on other projects...
As far as low-end boards like Netduino go, sockets is pretty straightforward and should work well for you.
Posted 18 March 2011 - 11:02 PM
Hi Calum,
By the way, GHI officially supports Wiznet's W5100 natively on FEZ Panda and FEZ Domino. You get TCP server/client + UDP + DHCP + HTTP + DNS, all at minimal memory usage, basically about 60KB RAM and 140K FLASH is left free. The speed is very comparable to netduino+ too. This is not open source but it is commercially supported.
Gus Issa
GHI Electronics
Edited by webmaster, 19 March 2011 - 03:55 AM.
Added vendor signature
Posted 18 March 2011 - 11:53 PM
any idea how much free ram id be seeing with http assemblies loaded? On the netduino plus im seeing about 20k at startupBy the way, GHI officially supports Wiznet's W5100 natively on FEZ Panda and FEZ Domino. You get TCP server/client + UDP + DHCP + HTTP + DNS, all at minimal memory usage, basically about 60KB RAM and 140K FLASH is left free. The speed is very comparable to netduino+ too. This is not open source but it is commercially supported.
Posted 19 March 2011 - 02:51 AM
I don't have a FEZ to test it now but I saw this on GHI forum today. This user has a 5KB stream in his test application running with HTTP and his first GC run returns 40K. So my guess it is more than 50KB if you only add HTTP. http://www.tinyclr.com/forum/13/2727/
There is a detailed demo that ships from Microsoft about HTTP. It is not a small app and it runs fine on FEZ Panda. Find it at "...\Documents\Microsoft .NET Micro Framework 4.1\Samples\HttpServer"
It is very nice, give it a try.
Gus Issa
GHI Electronics
Posted 19 March 2011 - 03:54 AM
Hey there Gus,
Could you please add a "Gus Issa, GHI Electronics" signature to your posts? [Moderator will go ahead and add it to the bottom of your current posts for your convenience.]
We don't have a "no advertising" policy in the Netduino community, but we do need vendors to disclose their identity and relationship to their products.
We could also change your display name to "GHI Electronics" if that works better for you?
Also, if you could PM me with a bechmark to back up the "speed is very comparable" claim I'd really appreciate it. We've benchmarked the WIZnet solution on several boards and have never been able to approach even half of the native 1mbps offered by the Netduino Plus's built-in networking. Generally WIZnet has proven to be 3-7 times slower.
Thank you, Gus.
Posted 19 March 2011 - 12:48 PM
Hey there Gus,
Thank you, Gus.
Oh sorry! It is a bad habit of mine, will sign posts in future. Also, no advertising here but being informative, a developer is going for FEZ Cobra and you suggested tahoe, I am informing him that a little FEZ Panda will probably do the job. What makes networking on FEZ Panda support fast and reliable is that we wrote the divers natively not in C# and the interface is hooked to standard "socket" interface, so it is fast and with standard socket interface. In comparison, when plugging W5100 to netduino, the drivers are usually made in C# so in this case it is much slower like you said. Yes someone can write native driver but then first they have to do the work, it took us about 3 months, and second they need a +$6000 RVDS compiler as using GCC will degrade performance and blow up the firmware, which is why you use RVDS I assume?
As far as the speed test we have done, we first wanted to run the official Microsoft HTTP example on FEZ Panda and netduino+ to compare speed but sadly I remember we couldn't because the example won't fit on netdiuno+ due to its limited memory, please give it a try and correct me if I am wrong. It has been a while so maybe netduno+ offer more memory now?
So we made a smaller example that doesn't use HTTP to transfer a file over the network. The test showed 950Kbps on netduino+ and 400kbps on FEZ Panda. You already own FEZ Panda so it maybe a good idea to try on your end?
When it comes to performance, I would also like you to compare the SD write/read speed
Finally, this is our dedicated NETMF community website (forum/open source drivers/wiki/free ebooks) http://www.tinyclr.com/ so if anyone has questions on FEZ then the community and our engineers will be more than happy to assist.
Gus
GHI Electronics
Posted 19 March 2011 - 01:50 PM
Thanks God it is just informations and not ads!...Also, no advertising here but being informative
If I were looking for a C++ development board, then I will go probably to any Arduino-like device. What I want is *just* use C# and .Net (and I am debating a lot on this argument).What makes networking on FEZ Panda support fast and reliable is that we wrote the divers natively not in C#
Also remind to GHI's guys our community (forum/open source/wiki) http://forums.netduino.com/. Just in case they're in trouble with C#/NetMF/HardwareFinally, this is our dedicated NETMF community website ...
I am not versus GHI's product/company, but I guess that this is a place where some friends are talking each other, learning and make experimentation. That's unfair-play.
Posted 19 March 2011 - 02:26 PM
