![]() Networked music player using the mini
Started by hanzibal, Mar 17 2011 07:39 PM
71 replies to this topic
Posted 17 March 2011 - 07:39 PM
Hi there!
My project is about creating a networked music player using the Netduino mini and a vs1053 mp3 decoder chip. I know there are lots of streming music players out there alyready and even though I got some special plans for my little baby, I'm mostly doing this for the pleasure of it.
Currently, I'm kinda concept proofing, but it's going pretty well. Got the mini hooked up to a vs1053 breakout board from Sparkfun (rectified version), SD card, a pushable rotary encoder and a class D amplifier chip from Texas connected to a pair of monitor speakers. The latter is merely for sound quality testing and playing my favourite tunes while working with the project
![]() ![]() Attached Files
Posted 17 March 2011 - 07:48 PM
Hi hanzibal,
That's pretty neat! Any chance you have a video to share?
Posted 17 March 2011 - 08:14 PM Thanks, I'm currently uploading a clip to youtube, file's too large for upload here I think. I'll return shortly with a URL.
Posted 17 March 2011 - 08:28 PM Here's a clip recorded on my iPhone in sub-optimal lighting, but I woke my daughter recording it so have mercy ![]()
Posted 17 March 2011 - 08:30 PM
Apparently, I got two right speakers
Posted 18 March 2011 - 06:50 AM
Which version of the vs1053 product did you use? Sparkfun returns a few results when searching on vs1053. Nice video. Regards Mark To be or not to be = 0xFF
Blogging about Netduino, .NET, STM8S and STM32 and generally waffling on about life Follow @nevynuk on Twitter
Posted 18 March 2011 - 08:46 AM Hi Mark, it's a rectified version of Sparkfun's breakout board for the VLSI vs1053b, found here: http://www.sparkfun.com/products/8954 Since I contacted them regarding an issue with the TEST/DREQ pins, they've corrected their bob by soldering a jumperwire from the TEST pin to IOVDD. Excellent customer care there!
Posted 18 March 2011 - 09:10 AM
The project sounds good (in all ways
Posted 18 March 2011 - 01:07 PM Hi Mario! Well, the Netduino mini controls the vs1053 digital music decoder and the SD card as two slaves on a shared SPI bus. The rotary encoder generates interupts for the Netduio to interpret and perform the corresponding volume adjustment on the vs1053 as well as skipping to the next song, i.e. start reading a different file from SD. During playback, the Netduino orchestrates the streaming of mp3 files from SD card to the vs1053 via an internal 16 kB cyclic read ahead buffer (basically a FIFO) in RAM, while simultanoously keeping track of the rotary and more to come. Ok, during normal operation the Netduino mostly shuvels data from SD to vs1053, and sure, I could have done this by uploading custom software into the vs1053 thus omitting the Netduino. But I could never have done that in 2 weeks time and not in C# and the full confort of Visual Studio 2010 with all that comes with it terms of debugging capabilities and so forth. Especially not since I'm a software man and haven't dealt with any type of MCU whatsoever until about a month ago.
Posted 18 March 2011 - 01:15 PM
hanzibal,
Thanks for sharing this. Really cool project.
Posted 18 March 2011 - 03:38 PM What? Let's consider a MP3 song played at 128KB/s (maybe less), that is 16KBytes/s. Did you written a C# program that is able to flow 16KBy/s, without any native driver? Let me know a little more about. Cheers Mario
Posted 18 March 2011 - 06:52 PM
I have realized that the data transfer to/from SPI (or TCP/IP) is very fast, because it is made by the low level libraries. If you try to search among the latest threads, I had a problem (big word) on reading ADCs. That is a very common activity, with tons of apps, but it seems there's no way to do without hacking something in C++.
That is a pity.
This thread is pushing me to think seriously toward some missing blocks of this framework. It has no sense that you may transfer KB/sec and there are many difficulties to perform even the most basic activities.
That is surely a big fault.
Mario
Posted 18 March 2011 - 07:05 PM
Hi Mario,
What issue were you having with ADC readings again?
Posted 19 March 2011 - 05:25 AM
Chris, I am not having any problem at all, from the hardware and firmware viewpoint: the device does exactly what it says.
Now the risk is going a bit off-topic, but I think there are some considerations to do about Netduino+NetMF and the driver set.
Fred shown us that the http networking is able to run up to 95KB/s: absolutely wonderful.
Hanzibal is able to transfer 32KB/s (192Kb/s) from to SPIs: over than expected.
These functions are quite fast because the managed part is minimal and the dirty work is done by native code. However Netduino is *not* a PC and it best fits to integrate with hardware stuffs. So I think that it should be greatly improved in the MF the ability to interface hardware, while the managed part should only the glue-logic.
Just to make some examples...
Reading periodically one or more ADCs is a very very common activity. There are tons of applications around it: digital filtering, smart-sensors, data streaming, etc. The problem is that is *not* possible until you write a custom driver in C++. Via C#, I think I can't reach over 100samples/s.
That's the way it should be present a kind of "ADC sampler" or whatever else.
Also reading I/O ports is very common, but toggling a single pin takes over 100us. Why there is not any "read/write-all-pins"?
Closing...
I have noticed that the C#+NetMF give an high level of abstraction than the classic native coding, but that is costing too much for practical applications. I really think that we should consider some more "hardware-oriented" API to circumvent the limitations of the current device.
I am ready to work on, if you need.
Posted 19 March 2011 - 07:47 AM
Made a few tests and even 320kbps (48kHz sampling rate) CBR mp3 files plays beautyfully. As I gather, 320kbps (kilobits per second) corresponds to 40kB/s (kilobytes per second) as one byte is 8 bits and so 192kbps is equal to 24kB/s.
SPI clock speeds used are 5 MHz for the vs1053 and probably a great deal faster for SD. I've been asking questions in the forum trying to find out actual SD speed but haven't got any replies yet. I haven't got a scope or analyzer yet, but maybe someone could please check for me?
EDIT: Found out from Chris that SD clock speed is 10 Mhz.
My only sound related problem right now, is a low level background beep which I think is coming from SPI speed switches. These are creating spikes that are induced and transferred to the amplifier. The beep has different frequencies depending on the bitrate of the song being played due to different intervals between SD reads. Also the beep disappears for a short while when skipping to another song as no SD reads take place during a deliberate delay in code.
Any ideas of how to get rid of the beep?
Posted 23 March 2011 - 08:02 AM
Yesterday I started a C# port of Async Labs uIp driver for ZG2100 as I suspect that be pretty much the same chip as MRF24WB0MB from Microchip since they took over ZeroG. Documentation is close to nothing on both and I guess that's because of license NDAs or similar.
Anyway, attached is an image of my homemade MRF24WB0MB breakout board. At one point I think I got Netduino talk SPI to the thing but I messed up while trying to read debug messages from the MRF24WB0MB and now my mini needs reflashing or worse.
#19
Posted 25 March 2011 - 09:43 AM
Nope, the ZG2100 is not quite the same as MRF24WB0MB. Instead I'm now rewriting the driver based on the code for Light Shield 7 of SaikoLED which is based on the Async Labs stack, which in turn is based on the uIP stack from Andreas Dunkel
![]() With the help of Chris and Fred, I managed to resurrect my mini last night. Now it seems as if I've somehow flawed the wifi chip though so a new one is on it's way. With any luck, I'll hope to have the driver up and running soon...
#20
Posted 25 March 2011 - 02:13 PM
this project is awsome I was actually thinking about a mp3 alarm clock using the plus.
Terry Massey 0 user(s) are reading this topic0 members, 0 guests, 0 anonymous users | ||||||||||||||
