Anyone know anything about hooking up a pH sensor to Netduino? Trying to source, and then control, an in-line micro sensor.
I've read a little about ISFET probes.
pH sensor
Started by MattEric, Mar 12 2011 05:29 PM
Posted 12 March 2011 - 05:29 PM
Posted 12 March 2011 - 06:55 PM
You can have a look at phduino project for inspiration. pH meter is basically a millivoltmeter, pH probes (both glass and ISFET) output voltage depending on the value of pH (i.e. several millivolts per pH unit), so you need to amplify the voltage with operational amplifier circuit and then wire it to microcontroller analog input (A/D converter). For precise measurements, you'd also need calibration and temperature compensation.Anyone know anything about hooking up a pH sensor to Netduino? Trying to source, and then control, an in-line micro sensor.
Posted 12 March 2011 - 07:23 PM
You can get ISFET probes (and meters) at ISFETCOM (also note their claim about copycats). Depending on your usage scenario, you may need industrial grade probes (long-term immersion, food industry etc.), which are rather expensive...I've read a little about ISFET probes.
