Is there a netduino SDK documantation available?
Posted 12 March 2011 - 10:35 AM
Posted 13 March 2011 - 02:34 PM
Because of that no using statement can be used.
Is there a reason why IDisposable is not implemented?
Posted 26 March 2011 - 01:42 PM
Posted 26 March 2011 - 02:56 PM
Have a look here: Netduino Pinout DiagramsA document which lists the pin's functions (UART, etc.) would be great.
Posted 26 March 2011 - 04:31 PM
We should have documentation available for the v4.1.1 classes when v4.1.1 is officially release.
Most of the classes are in the .NET MF core. Documentation at Microsoft.com
In the meantime, if you have any questions about the AnalogInput, PWM, StorageDevice, or DeploymentTransport classes...just ask and we'll be happy to help.
Posted 26 March 2011 - 05:43 PM
Thanks, exactly what I'm looking for.Have a look here: Netduino Pinout Diagrams
Posted 26 March 2011 - 05:46 PM
Sounds good.[...] We should have documentation available for the v4.1.1 classes when v4.1.1 is officially release.
May you can point out why your classes (AnalogInput, PWM, etc.) provide a method called Dispose(), but do not implement the IDisposable interface.[...] In the meantime, if you have any questions about the AnalogInput, PWM, StorageDevice, or DeploymentTransport classes...just ask and we'll be happy to help. [...]
Posted 26 March 2011 - 06:12 PM
That was an error in their original implementation. To make it easy to update to v4.1.1, we have not updated the interfaces (lest we create versioning issues for Visual Studio).May you can point out why your classes (AnalogInput, PWM, etc.) provide a method called Dispose(), but do not implement the IDisposable interface.
This has been fixed in the v4.2 SDK, which will ship alongside .NET MF 4.2 later this year.
Posted 16 July 2014 - 12:52 PM
As a C# developer, I fully understand most of the Microsoft Net functions. However your implantation for the Netduino Plus 2 will have special syntax for all of the board / CPU pin functions. The question most asked on this site is there a SDK/API for your added functions.
E.G.
1) UART , Board rate , protocol TX and RX pins etc.
2) General IO Pins , Tri-state , pull up / down resistors
3) PWM structure and pin selection
4) I2C structure CAN Structure
5) A To D and if any D to A structure
6) Flash , Memory card basic to .net System I/O
7) Timers, Watch Dog
8) Other CPU ST hardware features.
All of this will not be found by the user looking in MSDN, as the only Microsoft bit is the ARM.net port from X86.net (32 bit and 64bit?)
probably first started by MS for the Spot project. I'm not sure if Microsoft even gave value to the ARM embedded microcontroller market?
Which gave rise to so many Linux clones, Android , Raspberry PI to name just a few.
Windows CE, Windows Embedded is now just land fill.... Windows 8 mobile / RTC well that's just another none standard ARM product!
The "Glue" firmware added by Secret Labs is a real way forward for .net to breach a massive "Smart" microcontroller world, working with Microsoft's huge PC code base (even if MS does not seam to care about it)
Please make your API stand out when MSDN's is lost in space.
Best Regards
Any pointers for me will help others looking at this reply.
- NameOfTheDragon likes this
