I have used the i2cmaster.h when i was working with arduino. Now i try to convert it to C# but i dont understand it.
Can some pleas help me convert this code to c#.
Having just figured out I
2C myself, I can tell you that you don't have the same (low) level of control over I
2C in C# (NETMF). The
I2CTransaction wraps the complexities of the protocol and handles the start/stop/acks for you.
Here's some basic test code that I used to read/write a 24LC32A serial EEPROM:
byte[] buffer = new byte[1];
int bytesWritten = 0;
// Create the I2C device (device address: 0x54, clock rate: 50Khz)
I2CDevice.Configuration i2cConfig = new I2CDevice.Configuration(0x54, 50);
I2CDevice eeprom = new I2CDevice(i2cConfig);
// Write the letter 'A' (0x41) to address 0x0000 on the eeprom
I2CDevice.I2CTransaction[] writeTx = new I2CDevice.I2CTransaction[] { CreateWriteTransaction(new byte[] { 0x00, 0x00, 0x41 }, 0, 0) };
bytesWritten = eeprom.Execute(writeTx, 1000);
// Read the byte at address 0x0000 on the eeprom
I2CDevice.I2CTransaction[] readTx = new I2CDevice.I2CTransaction[] { CreateReadTransaction(buffer, 0x0000, 2) };
do { bytesWritten = eeprom.Execute(readTx, 1000); } while (bytesWritten == 0);
Debug.Print(buffer[0].ToString());
#region see: http://forums.netduino.com/index.php?/topic/944-i2c-internaladdress-repeated-start-bit-support/
static I2CDevice.I2CWriteTransaction CreateWriteTransaction(byte[] buffer, uint internalAddress, byte internalAddressSize)
I2CDevice.I2CWriteTransaction writeTransaction = I2CDevice.CreateWriteTransaction(buffer);
Type writeTransactionType = typeof(I2CDevice.I2CWriteTransaction);
FieldInfo fieldInfo = writeTransactionType.GetField("Custom_InternalAddress", BindingFlags.NonPublic | BindingFlags.Instance);
fieldInfo.SetValue(writeTransaction, internalAddress);
fieldInfo = writeTransactionType.GetField("Custom_InternalAddressSize", BindingFlags.NonPublic | BindingFlags.Instance);
fieldInfo.SetValue(writeTransaction, internalAddressSize);
return writeTransaction;
static I2CDevice.I2CReadTransaction CreateReadTransaction(byte[] buffer, uint internalAddress, byte internalAddressSize)
I2CDevice.I2CReadTransaction readTransaction = I2CDevice.CreateReadTransaction(buffer);
Type readTransactionType = typeof(I2CDevice.I2CReadTransaction);
FieldInfo fieldInfo = readTransactionType.GetField("Custom_InternalAddress", BindingFlags.NonPublic | BindingFlags.Instance);
fieldInfo.SetValue(readTransaction, internalAddress);
fieldInfo = readTransactionType.GetField("Custom_InternalAddressSize", BindingFlags.NonPublic | BindingFlags.Instance);
fieldInfo.SetValue(readTransaction, internalAddressSize);
return readTransaction;
#endregion
Make sure you have the
4.1.1 ALPHA 7 firmware.
Hope that helps.
