Netduino Mini Firmware v4.1.0 (update 6)
Started by Chris Walker, Mar 03 2011 06:29 AM
1 reply to this topic
Posted 03 March 2011 - 06:29 AM
Here is the Netduino Mini firmware. This is a recommended update for existing users.
IMPORTANT NOTE: select the appropriate firmware zip file (RS232 or TTL) based on the deployment port you are currently using (RS232 = pins 1 and 2; 3.3V TTL UART = pins 11 and 12).
Version: 4.1.0 Update 6 (version 4.1.0.6)
152KB Flash
70KB RAM
1. RS232 and TTL UART deployment now selectable via software tool
2. Garbage collection 'status messages' updated
3. Bugfixes: SerialPort.DataReceived event should now fire properly
4. Bugfixes: SerialPort.Read() timeout now implemented properly
5. Bugfixes: Misc. SPI bugfixes
To find the current version of your Netduino Mini firmware:
1. Go to the Start Menu > Programs > Microsoft .NET Micro Framework 4.1 > Tools
3. Plug your Netduino Mini into your PC using an RS232 or TTL UART cable.
4. In the Device section at top, select Serial. Select the serial port assigned to your RS232 or TTL UART cable.
Users of firmware version 4.1.0.5 or earlier may update to this new firmware using the MFDeploy tool:
2. Go to the Start Menu > Programs > Microsoft .NET Micro Framework 4.1 > Tools
- Snympi likes this
Posted 03 March 2011 - 06:31 AM
Some users may erase their Netduino Minis completely to use them as low-cost ARM development boards or to otherwise tinker. In this case, it will necessary to redeploy the TinyBooter bootloader before redeploying the Netduino Mini firmware.
Reflashing a Netduino Mini after a full erase requires an RS232 connection to your Netduino Mini.
The TinyBooter booloader (v4.1.0.6) is attached to this post for your convenience.
- Snympi likes this
