The ERASE pad must be connected to 3.3 V (logic High) for at least 220 ms :-) I think I tried to deploy TinyBooterDecompressor.hex using MFDeploy and it worked. But the documentation says that bootstrap blocks cannot be overwritten, so I would rather suggest you using SAM-BA for this, as it is the official and supported way...., I have to erase flash. I do it by connecting 3.3V on ND to a spot near onboard LED for ~3 seconds. Is this necessary or is there a simpler way to deploy TinyBooterDecompressor?
Congrats! Now, you just need to make the LCD driver feature appear in SolutionWizard so you can enable it, rebuild the firmware and you are done (as described in readme.txt enclosed in KS0108_Driver.zip).And, I want to report, that I've successfully deployed the vanilla firmware I've built (with a lot of help from you guys!). So now, I can get back to LCD tinkering and see what the heck is going on with this KS108B of mine.
