NEC Protocol IR Decoder
7 replies to this topic
#1 darko
darko
Posted 18 February 2011 - 08:35 AM
I purchased an IR kit from DFRobot for a project that I am working on. The remote control sends pulses encoded in the NEC protocol. The following is a class which I wrote which handles decoding the ir command.
The idea of how to implement it was based on how the forum member 'phil' did it in his RC6 Decoder class.
When a code is received, the OnIrCommandReceived event is called and is passed the decoded 32 bit number. Eg. on the remote the 0 button returns 217268479, the 1 returns 284115199.
Note: apple remote controls also use the NEC protocol, so its possible to decode apple remote commands with this class.
public class NecRemoteControlDecoder
    private Cpu.Pin _irReceiverPin;
    private long[] pulses;
    private int currentPulseIndex;
    private Timer irPulseTimeOutTimer;
    public delegate void IrCommandReceivedEventHandler(UInt32 irData);
    public event IrCommandReceivedEventHandler OnIrCommandReceived;
    private InterruptPort irReceiverPort;
    public NecRemoteControlDecoder(Cpu.Pin irReceiverPin)
        _irReceiverPin = irReceiverPin;
        pulses = new long[200];
        currentPulseIndex = 0;
        irReceiverPort = new InterruptPort(irReceiverPin, false, Port.ResistorMode.Disabled, Port.InterruptMode.InterruptEdgeBoth);
        irReceiverPort.OnInterrupt += new NativeEventHandler(irReceiverPort_OnInterrupt);
        irPulseTimeOutTimer = new Timer(new TimerCallback(IrPulseTimeOut), null, Timeout.Infinite, Timeout.Infinite);
    private void irReceiverPort_OnInterrupt(uint data1, uint data2, DateTime time)
        if (currentPulseIndex >= 200) currentPulseIndex = 0;
        pulses[currentPulseIndex] = time.Ticks;
        currentPulseIndex++;
        irPulseTimeOutTimer.Change(10, Timeout.Infinite);
    private void ConvertPulsesToMicroseconds(long numberOfPulses)
        var firstMicrosecondsValue = pulses[0] / (TimeSpan.TicksPerMillisecond / 1000);
        var lastMicosecondsValue = firstMicrosecondsValue;
        for (int i = 1; i < numberOfPulses; i++)
            var currentPulseMicrosecondsValue = pulses[i] / (TimeSpan.TicksPerMillisecond / 1000);
            var currentPulseLength = currentPulseMicrosecondsValue - lastMicosecondsValue;
            lastMicosecondsValue = currentPulseMicrosecondsValue;
            pulses[i - 1] = currentPulseLength;
    private void IrPulseTimeOut(object state)
        var numberOfPulses = currentPulseIndex;
        irPulseTimeOutTimer.Change(Timeout.Infinite, Timeout.Infinite);
        ConvertPulsesToMicroseconds(numberOfPulses);
        if (numberOfPulses != 68) return;
        if (!IsPulseMatch(pulses[0], 9000) || !IsPulseMatch(pulses[1], 4500)) return;
        UInt32 data = 0;
        for(int i = 65; i >= 3; i--){
            if((i % 2) == 1){
                data = data << 1;
                if (IsPulseMatch(pulses[i], 565))
                    data = data | 1;
            else{
                if(!IsPulseMatch(pulses[i], 560))
                    return;
        if (OnIrCommandReceived != null)
            OnIrCommandReceived(data);
    private bool IsPulseMatch(long actualValue, long expectedValue)
        var marginOfError = 200;
        if ((expectedValue - marginOfError) < actualValue && (expectedValue + marginOfError) > actualValue)
            return true;
        return false;
Sample usage:
namespace Netduino.NecRemoteControlDecoderApp
            var necRemoteControlDecoder = new NecRemoteControlDecoder(Pins.GPIO_PIN_D0);
            necRemoteControlDecoder.OnIrCommandReceived += necRemoteControlDecoder_OnIrCommandReceived;
        static void necRemoteControlDecoder_OnIrCommandReceived(UInt32 irData)
            Debug.Print("Ir Command Received: " + irData);
#2 Mercules
Mercules
  • 4 posts
Posted 28 January 2012 - 05:17 AM
This is great! Thank you for this very helpful class. Now I just need to figure out how to send signals...
#3 hanzibal
hanzibal
  • 1287 posts
  • LocationSweden
Posted 12 February 2012 - 06:02 PM
Perfekt, I picked up one of these detectors a couple of weeks ago and I will use your code for my usb audio project.
Thanks!
#4 hanzibal
hanzibal
  • 1287 posts
  • LocationSweden
Posted 13 February 2012 - 09:22 AM
Btw, did you connect the detector data line directly to your Netduino pin or did you go through a voltage divider in order to get 3,3V?
EDIT: The detector seem to work equally well when fed only 3.3V. Your code completed my USB audio project. Thanks!
#5 hanzibal
hanzibal
  • 1287 posts
  • LocationSweden
Posted 18 February 2012 - 10:01 PM
A suggestion or request if I may: I would like to receive an event when a button is released - this in order to implement repeating buttons for volume etc.. Maybe there are other possibilities such as general button repetitions from the remote. Either way, this would be a greatly appreciated extension of the class. So, what sayeth thee - can you do it or need I attempt to undertake such a conduct myself?
#6 Bondolon
Bondolon
Posted 28 February 2012 - 05:22 AM
Awesome post darko. I had a remote that implemented this protocol and one of the 38kHz IR receivers from Radio Shack (276-640), and used your code to help decode it. That said, I noticed that I was getting a number of incorrect values (the most common being that the number was shifted two bits too many to the left, though I was getting some just random outliers), and revamped the code a little to clean up the integrity of the received signals. I only know that it works with the Apple Remote (the only one I have on hand that implements this protocol), though I saw the same 9000->4500 control sequence on a completely different remote--a JP1.3 from SuddenLink. Either way, the modifications below have a bit more overhead in terms of memory, but they seemed to constrain the values very closely to what I was expecting (e.g. my first test with them replaced the OnIrCommandReceived call with a debug block for breaking when >50 valid values had been retrieved, and it stopped after exactly 51 button clicks).
namespace NecDecoder
    class NecProtocolDecoder
        public event IRCommandEventHandler OnIRCommandReceived;
        private Timer _timeout;
        private InterruptPort _input;
        private long[] _pulses;
        private int _currentIndex;
        public NecProtocolDecoder(Cpu.Pin irReceiverPin)
            _timeout = new Timer(new TimerCallback(PulseTimedOut), null, Timeout.Infinite, Timeout.Infinite);
            _input = new InterruptPort(irReceiverPin, false, Port.ResistorMode.Disabled, Port.InterruptMode.InterruptEdgeBoth);
            _input.OnInterrupt += new NativeEventHandler(OnInterrupt);
            _pulses = new long[200];
            _currentIndex = 0;
        private void OnInterrupt(uint data1, uint data2, DateTime time)
            if (_currentIndex >= 200)
                _currentIndex = 0;
            _pulses[_currentIndex++] = time.Ticks;
            _timeout.Change(10, Timeout.Infinite);
        private void PulseTimedOut(object state)
            const long toMicrosecondsDivisor = TimeSpan.TicksPerMillisecond / 1000;
            var firstValue = _pulses[0] / toMicrosecondsDivisor;
            var lastValue = firstValue;
            for (int i = 1; i < _currentIndex; i++)
                var currentValue = _pulses[i] / toMicrosecondsDivisor;
                _pulses[i - 1] = currentValue - lastValue;
                lastValue = currentValue;
            uint result = 0;
            int controlIndex = 0;
            int collectedLength = 0;
            bool isCollecting = false;
            for (int i = 0; i < _currentIndex; i++)
                if (!isCollecting && (IsInRange(_pulses[i], 9000, 200) && IsInRange(_pulses[i + 1], 4500, 200)))
                    controlIndex = i;
                    i = i + 2;
                    isCollecting = true;
                else if (isCollecting && collectedLength < 32)
                    if ((i - controlIndex) % 2 == 1)
                        result <<= 1;
                        collectedLength++;
                        if (IsInRange(_pulses[i], 1690, 200))
                            result |= 1;
            _currentIndex = 0;
            if (OnIRCommandReceived != null)
                OnIRCommandReceived(result);
        private static bool IsInRange(long pulse, long expected, long tolerance)
            return (expected + tolerance > pulse && expected - tolerance < pulse);
    public delegate void IRCommandEventHandler(uint command);
#7 hanzibal
hanzibal
  • 1287 posts
  • LocationSweden
Posted 13 March 2012 - 07:48 PM
Turns out, this 1.95$ IR-receiver does the same job as the DFRobot thing:
http://www.sparkfun.com/products/10266
Actually, a similar one is installed on the DFRobot. Should have done my homework Posted Image
#8 irda
irda
  • 4 posts
Posted 05 January 2014 - 08:34 PM
Good job, it's very usefull. Can you explain how the code working?
