How do you create software events
5 replies to this topic
#1 alanb
alanb
  • 28 posts
  • LocationNottingham UK
Posted 17 February 2011 - 06:42 PM
So far I have created a display manager class, that internally creates a thread listening on a socket for commands. That all works fine, the main thread generates numbers on a display and sending a message from a client on my pc will display that message on the display.
Now when my displaymanager recieves a command code on the socket I want to pass that command back to the main program. On the pc I would usually use an event. When I looked for EventHandler<> I could only find something called NativeEventHandler. Is that the N+ equivalent of EventHandler?
What is the equivalent of my pc code
public event EventHandler<StringEventArgs> ReceivedCommand;
In Some function
if (ReceivedCommand != null)
   ReceivedCommand(this, new StringEventArgs(command));
Or, as is highly probable, am I going about this in the wrong way.
By the way, a lot of this code is by others from the forum so if you recognise your own code, profound thanks. I will reference everyone in the finished article.
Alan
#2 Dan Morphis
Dan Morphis
  • 188 posts
Posted 17 February 2011 - 07:28 PM
You would indeed use an event, but not in the .NET 2.0 way of using public event EventHandler<SomeEventArg> MyEvent;
The equivilent in NETMF is
public class SomeClass {
    public delegate void MyEventDelegate(object sender, MyEventArgs e);
    public event MyEventDelegate MyEvent;
    public class MyEventArgs : EventArgs {
    private void OnMyEvent(MyEventArgs e) {
        var handler = MyEvent;
        if (handler != null) {
           handler(this, e);
   public void DoSomething() {
       OnMyEvent(new MyEventArgs());
#3 kenNET
kenNET
  • 69 posts
  • LocationSweden
Posted 17 February 2011 - 07:33 PM
Have a look the changes I did to the RDIF code here: http://forums.netdui..._7220#entry7220 (look after //(** new **)) There I use delegate and event in NETMF.
#4 alanb
alanb
  • 28 posts
Posted 17 February 2011 - 09:02 PM
Thanks for the information, now all working correctly. Thanks also to Dan for the same solution.
Alan
#5 VipX1
VipX1
  • 6 posts
  • LocationDublin, Ireland
Posted 26 February 2012 - 01:00 PM
:rolleyes:
Thanks guys, that delegate declaration is exactly what I needed and I was scrolling threw various .NetMF sites and blogs but couldn't find it. Then I thought everyone who got a Netduino had this situation...
Am I right in saying that the EventHandler must be executed this way because .NetMF doesn't support Generics?
Cherrs, VipX1.
#6 Chris Walker
Posted 26 February 2012 - 04:04 PM
Hi VipX1, You are correct. Since .NET MF doesn't support generics, you'll want to use the traditional event method built into .NET 1.0+ (as outlined by Dan Morphis). Chris
