Automated Build and Deploy
Posted 15 February 2011 - 06:45 PM
Posted 15 February 2011 - 11:30 PM
Posted 16 February 2011 - 07:45 AM
Just reading this post and the final paragraph states:If you want to build your code at the command-line, follow the instructions in the following post:
http://forums.netdui...ndpost__p__9459
To run your Mono-compiled app, copy the resulting MonoNetduinoApp.pe file to a MicroSD card and insert it into your Netduino Plus (or use a shield on your Netduino or a MicroSD breakout board with your Netduino Mini). The MonoNetduinoBootloader app on your Netduino will then load the app automatically during powerup/restart.
Could this be used for application distribuation (it may answer this question: http://forums.netdui...ch__1#entry9395)?
Are there any limitations / known problems with using this as a method of distributing updates?
Posted 16 February 2011 - 08:29 AM
Yes, absolutely. You could even download updates over the Internet and put them on an SD card. And then load them in (or reboot and load in only the new firmware).Could this be used for application distribuation?
Your code will be loaded into RAM and run from there...so it'll reduce available RAM somewhat.
Posted 16 May 2011 - 04:03 PM
For deployment, you'll need to use the MFDeployEngine (perhaps via PowerShell .NET scripting?). We're working on a command-line way to do deployment that MonoDevelop will use...you'll be able to use this in your own deployment scripts as well. That's a few months out though.
Is it possible to use the command-line deployment now?
Thanks.
Posted 16 May 2011 - 04:11 PM
Yes, although the process is still in beta (and you might need to whip up a few lines of glue code). Check out the Mono forum for more details.Is it possible to use the command-line deployment now?
Posted 16 May 2011 - 04:48 PM
Ok thanks I'll have a look there.Yes, although the process is still in beta (and you might need to whip up a few lines of glue code). Check out the Mono forum for more details.
