Sub routines with LED flash
sub routine subroutine
1 reply to this topic
#1 vader7071
vader7071
  • 132 posts
  • LocationDothan, AL
Posted 04 October 2016 - 01:15 AM
Here is the issue I have,  I am using a Netduino 1 to control (4) LEDs.
I need each LED to flash at a different rate.
Below is the code I have created so far.
Here is my issue.  The brth() Thread.sleep(x) seems to be controlling everything.  I need to run each of these subs independently so if I adjust brth() it won't affect tLed(), mLed(), or bLed(), or where none of the others affect each other.
The bottom line question. What did I do wrong?
Thank you in advance for your help.
Oh, forgot to mention the bad news.  I need this working in 2 days.  Yeah.  I just had this idea.  I'm an idiot.
namespace VaderChestBox
    // Variables
    //Digital Inputs
    //Digital Outputs
    static OutputPort led1 = new OutputPort(Pins.GPIO_PIN_D1, true);
    static OutputPort led2 = new OutputPort(Pins.GPIO_PIN_D2, false);
    static OutputPort led3 = new OutputPort(Pins.GPIO_PIN_D3, true);
    static OutputPort breath = new OutputPort(Pins.GPIO_PIN_D4, false);
    //Analog Inputs
    //Analog Outputs
      // write your code here
        tLed();
        mLed();
        bLed();
        brth();
    public static void tLed()
      // flash Top LED (LED1).  1.5 second cycle 50% duty.
      led1.Write(!led1.Read());
      Thread.Sleep(750);
    public static void mLed()
      // flash Middle LED (LED2).  3.7 second cycle 50% duty.
      led2.Write(!led2.Read());
      Thread.Sleep(1850);
    public static void bLed()
      // flash Bottom LED (LED3).  2.35 second cycle 50% duty.
      led3.Write(!led3.Read());
      Thread.Sleep(1175);
    public static void brth()
      // Trigger Breath Module.  5.1 second cycle 2% duty.
      breath.Write(true);
      Thread.Sleep(100);
      breath.Write(false);
      Thread.Sleep(5000);
#2 Nevyn
Nevyn
  • 1072 posts
  • LocationNorth Yorkshire, UK
Posted 04 October 2016 - 07:12 AM
Thought about using NETMF timers ?
http://blog.mark-ste...1/netmf-timers/
Alternatively, PWM ?
