Additional UARTs
Posted 13 February 2011 - 11:30 AM
I am looking for additional UARTs. So far I've found a single SPI/I2C->UART breakout board from Sparkfun and a dual UART (same, SPI/I2C) IC: SC16IS762 and a matching shield project <- I doubt that this one is in production or something.
Are there any other options? A quad UART would be nice . I guess only realistic option at this time is using 4 Sparfkun boards.
Miha Markic, Microsoft MVP C#
Righthand .net consulting and software development
http://blog.rthand.com/
Posted 13 February 2011 - 12:13 PM
Posted 13 February 2011 - 01:24 PM
Miha, happy to see there are friends closer than oversea!
Well, about the quad-uart...
Take a look at these chips: I think could fit for your probelm.
MAX3110E, MAX3111E
Mario
Hi neighbour!
From what I can read on MAX3111E it looks to me like it has a single UART (and a RS-232)? Is it possilbe to use RS-232 like one or more uarts?
Posted 13 February 2011 - 01:34 PM
Posted 14 February 2011 - 08:23 AM
Posted 14 February 2011 - 10:20 AM
The Netduino might a 3rd uart somewhere. The Netduino COM1 is actually the dbgu. Uart0 is the COM2. The uart1 is at PA4 and PA5 I think.
I recall something about this - that there is a driver under development for utilizing it or something.
I find it odd that there are no easy solutions to this problem (like a quad UART chip or two double chips on a breakout board or something) giving the fact that a lot of components communicate through TX/RX.
Posted 14 February 2011 - 11:19 AM
Posted 14 February 2011 - 12:11 PM
Posted 14 February 2011 - 12:42 PM
What about this one?
http://www.maxim-ic....dex.mvp/id/6560
The problems are: how much does it cost?...when will be available?...will you able to hand-wiring a 48-pin QFN package?...
Ciao!
Posted 14 February 2011 - 01:30 PM
Great project!...I'm trying to do something similar for my child, Lego based, but I have very few time...
Indeed, time is very scarce everywhere.
Now we are talking.
I don't think cost is a problem. However availability is a problem and bloody QFN package is even a bigger one. Are there any QFN -> normal package adapters out there?
Posted 14 February 2011 - 03:27 PM
If you're a soldering wizard (with a super-thin solder), you may try to connect a 48-pin DIP socket to the QFN wire-by-wire. I'd never able to do, but there's people able to make surgery on ants...
Mah!...try this:
http://www.nxp.com/#...S752_SC16IS762]
Good luck!
Posted 14 February 2011 - 04:20 PM
For example Proto-Advantage has QFN-48 to DIP adapter, but in general those are not cheap.Are there any QFN -> normal package adapters out there?
