Sorry for my bad English.
Is there a shield or some easy way to convert the 0-5 V PWM to 0-10v.
PWM 0-10V
Started by wisedf, Feb 10 2011 11:18 AM
Posted 10 February 2011 - 11:18 AM
Posted 10 February 2011 - 09:14 PM
Simply use a transistor. Small amplifying transistors will give you what you need.
like so:
like so:
Be patient with me, I'm new to this.
Posted 06 August 2012 - 07:44 PM
From a software standpoint, I am fully absorbing the concept of utilizing the Netduino PWM pins,amplifying the signal and subsequently controlling a low voltage 0-10v DC dimmer (like that on certain BuckPucks) but being more of a software developer than an electrical engineer, I am not following the circuitry.
Can someone list the exact components and diagram how to achieve this on a breadboard with either a transistor,opAMP or other circuit?
Essentially I want to use the Netduino to control dimming on a Luxdrive Buck Puck
Any assistance would be greatly appreciated.
Posted 07 August 2012 - 03:31 AM
Time ago I wrote this article: http://tinyclr.it/se...-power-led.aspx
It's a very basic way to dim an high-power led, but it should help.
It's in Italian, so please use any translator.
Posted 07 August 2012 - 02:19 PM
Thanks, that is indeed useful but I am really in need of circuit and specific components necessary to emulate the output of a 0-10v low voltage dimmer. Since the arduino PWM is done at 0-3.3v, I need a sketch on how to convert the netduino's 0-3.3v signalling to 0-10v which will be used to dim the following LED driver LuxDrive A009 BuckBlock
for me the circuit shown above using the "small amplifying transistor" is a start but I am not much of an electrical guru to know which specific pieces make up that circuit.
