I have a Netduino plus, and a ID-20 RFID reader. I've been able to read the serial data off the ID-20 exactly 2 times then everything quit working. I've verified on my o-scope that the ID-20 is still putting out what looks like serial data.
One thing I did notice that was interesting with the ID-20, is it keeps the serial line high when no data is present. I'm not sure what the ID-20 did before, because I just now put a scope on it.
Does anyone know what might be wrong? I've verified I'm using pin D0, and that the serial port is being opened at 9600,8N1. I've even tried moving to a different COM port with the same results.
Anyone have any advice?
var serialPort = new SerialPort(SerialPorts.COM1, 9600, Parity.None, 8, StopBits.One);
serialPort.DataReceived += OnDataReceived;
serialPort.ErrorReceived += OnErrorReceived;
serialPort.Open();
akcoder,
First of all, make sure that you're running the latest firmware (v4.1.0.6 RC1+ or v4.1.1 alpha 7+). There are a bunch of SerialPort enhancements and bugfixes in the new builds.
Do you have a logic analyzer...to see what is coming across the wire?
It looks like I'm running "Solution Build Info: 4.1.0.5, Netduino Plus by Secret Labs LLC". I'll upgrade to a 4.1.1 build.
No logic analyzer I'm looking to see if I can add that module to my scope (Rigol DS1052E), or get something like the USBee analyzer. What do you run/recommend?
akcoder,
There are lots of nice expensive logic analyzers out there, but I find myself reaching for the Saleae Logic most of the time. Amazing little unit for the money...
I updated to 4.1.1 a6 (I didn't see an a7 out there), and I still get the same thing I've verified that the ID-20 RFID reader is hooked up correctly, and that it can read a tag (the ID-20 puts out a 500 msec pulse on pin 10 when it reads a tag).
I've put the code into a loop and set it to print out the bytes avail, and it continually says 0.
Short of buying a logic analyzer to verify that the data coming into the Netduino is correct, do you have any other suggestions?
I've used the ID-20 with the Netduino (Standard) without a problem, so there's no inherent mismatch between the two. No code or circuit to hand I'm afraid, just tested it and disconnected it.
Fred, do you have an o-scope handy? Can you verify that pin 9 is held high when no data is present? You can also check this with a logic probe, or an LED (making sure to use a resistor)
akcoder,
Have you double-checked the baudrate and other serial port settings? I know that you mentioned it worked before, but I didn't see all the serial port in the datasheet...
Yeah, the serial port isn't listed in the data sheet for some odd reason, but everything I've read says its 9600,8N1 which I've verified.
I read over at arduino.cc a guy saying he had to put a 1k resistor between pins 4 & 5 to make it work. I'm guessing he blew something when he was probing around while it was hot. I'm wondering if I did the same thing... I'll give that a go tonight.
I hacked up a quick console app and connected the ID-20 to my laptop via a serial->usb adapter, and connecting at 9600,8N1 the data comes across, and is very consistent. So now I'm not sure why my Netduino isn't able to receive the data. I tried the resistor trick I mentioned and it had no effect on the outcome.
Thoughts?
Dan, if you connect the ID-20 to your laptop and get data via a USB->RS232 adapter, then it's likely outputing at RS232 voltages.
RS232: -12V to 12V
TTL: 0V to 3.3V (or 0V to 5V)
If you hook up RS232 signals to the digital pins on the Netduino, you can damage those pins. Do you have something that you can plug into D0 and D2 (LED, button, etc.) to make sure that they haven't been damaged?
RS232: -12V to 12V
Chris, I've checked this actually and the pin is operating fine. I've also checked the output from the ID20 and it is TTL voltages, not RS232 voltages. The usb->serial adapter I'm using happens to tolerate TTL voltages (as I've read many of your USB->serial adapters do).
Hi Dan,
Let's go back to basics then...
Can you please attach your actual source/solution as a ZIP file? This may not be electrically related after all...
I think I may have discovered the issue, I'll get back to you in a few after I confirm it (I believe my proto shield wasn't making full electrical contact w/ the Netduino, but only on pin D0, grr).
In the mean time, is there a Netduino code wiki or repository? I wrote some pin checker code I'd like to share in the hopes that it may help someone else in the future...
By the way, I wrote a nice little class to handle the ID card reader series, and then other members enhanced it. It works nicely - Be sure to check it out.
http://forums.netdui...d-reader-driver
Hi Dan,
Ah, I think you may have found the culprit. I didn't realize that there were other parts in your circuit.
We're working on a Wiki; for now, please share your code in the project showcase. Much appreciated!
Charles,
I actually saw that after I had written my own RfId class. I did steal some ideas from your stuff. I'll post mine to the project showcase when I get done.
After two days of trying to figure this thing out I finally have it licked! It was indeed what I intimated earlier. Everything works now like a charm!
