Bit shift operator worked in 4.2 but not in 4.3 - Netduino Plus 2 (and Netduino Plus 1) - Netduino Forums
#1 Joshk
Joshk
  • 72 posts
Posted 21 August 2016 - 06:27 PM
I was successfully using this code in the 4.2 framework to get the MAC address.
    Private Function getMacAddress(ByVal seperator As String) As String
        Dim netIF As NetworkInterface() = NetworkInterface.GetAllNetworkInterfaces()
        Dim macAddress As String = ""
        ' Create a character array for hexidecimal conversion.'
        Const hexChars As String = "0123456789ABCDEF"
        ' Loop through the bytes.'
        For b As Integer = 0 To 5
            ' Grab the top 4 bits and append the hex equivalent to the return string.'
            macAddress += hexChars(netIF(0).PhysicalAddress(b) >> 4)
            ' Mask off the upper 4 bits to get the rest of it.'
            macAddress += hexChars(netIF(0).PhysicalAddress(b) And &HF)
            ' Add the dash only if the MAC address is not finished.'
            If b < 5 Then macAddress += seperator
        Next
        Return macAddress
    End Function
But after having to upgrade to 4.3 when I setup my new computer, the code-check underlines the code
and gives this error if I try to deploy:
Error 1 Type 'System.Nullable(Of )' is not defined.
If I remove the ">> 4" part of the line the code-check is happy.  So why is that operator not supported?  Do I need a special import now?
#2 JoopC
JoopC
  • 148 posts
Posted 22 August 2016 - 06:08 AM
do this:
'UShort * 2^8 for left shifting 8 bit (<< 8)
'UShort / 2^8 for right shifting 8 bit (>> 8)
' X * 2 ^ Y for << left shifting
' X / 2 ^ Y for >> right shifting
'so 4 << 7 = 4 * 2 ^ 7
'so 5 >> 3 = 5 / 2 ^ 3
#3 JoopC
JoopC
  • 148 posts
Posted 22 August 2016 - 06:59 AM
MAC address
Public Function MACaddress() As String
Dim macInDecs As Byte() = NetworkInterface.GetAllNetworkInterfaces(0).PhysicalAddress
Dim strMacAddress = ""
For t As Integer = 0 To macInDecs.Length - 1
strMacAddress &= If(t = 0, "", ".") & macInDecs(t).ToString("X2")
Next
Return strMacAddress
End Function
#4 Joshk
Joshk
  • 72 posts
Posted 26 August 2016 - 03:24 AM
Thanks guys.  That looks like it will work, I will test it when I get a chance.
