Getting Started Pain
No replies to this topic
#1 millerabode
Posted 20 August 2016 - 09:20 AM
I've recently started developing a project using a Netduino 3 Wifi having not really used Netduino boards before. I have finally been able to write code in VS Express 2013 and executed it on the board but it took quite some time to get to this point as I originally tried to use the latest versions of everything and ran into problems - hence the following queries that people here may be able to answer:
I have updated the netduino firmware using the latest available on the site
The latest .net microframework is 4.4 - is this not supported by the latest firmware as changing the project to use this framework I get the following when deploying to the board:
Attaching deployed file.
Assembly: Microsoft.SPOT.Hardware.SerialPort (
* ERROR!!!!  Firmware version does not match managed code version!!!! *
* Invalid native checksum: Microsoft.SPOT.Hardware.SerialPort 0x4E6685A9!=0x1C1E5B6D *
Link failure: some assembly references cannot be resolved!!
Assembly: Object ( needs assembly 'get_Directory' (
Assembly: Object ( needs assembly 'Microsoft.SPOT.Net' (
Assembly: Object ( needs assembly 'Microsoft.SPOT.Native' (
Error: a3000000
Waiting for debug commands...
The program '[1] Micro Framework application: Managed' has exited with code 0 (0x0).
The other main issue was that I started trying to use Visual Studio 2015 Community Edition. I managed to get the Netduino templates available such that I could create a Netduino application but on trying to build the solution I get:
could not find library 'Microsoft.VisualBasic.dll'
How do I fix that?
Thanks in advance
