PwmGamma Sample
#1 dab
dab
  • 54 posts
  • LocationBellevue, WA, USA
Posted 18 August 2010 - 08:50 AM
As a follow-up to the PwmSample, CW2 suggested extending it to address the non-linear response of the LED.
After a bit of research, I found that this is referred to as "gamma correction", and even found an application note that discusses using gamma correction with PWM:
http://www.maxim-ic....dex.mvp/id/3667
So, here's an update to PwmSample that uses a pre-computed LUT (lookup table) for the PWM output values. These are the gamma-corrected values (for gamma = 2.5) that produce a brightness ramp that looks linear (more or less) to our eye.
Here's the code:
namespace PwmGamma
        const int pwmPeriod = 50;
        // Lookup table for the LED brightness.  The table contains the
        // gamma-corrected values (for gamma = 2.5).  This approximates
        // a linear increase in the perceived brightness.
        static uint[] gammaTable = {
             0,  0,  0,  0,  1,  1,  1,  2,  2,   3,
             4,  5,  6,  7,  9, 10, 12, 14, 16,  18,
            20, 22, 25, 28, 31, 34, 37, 41, 45,  49,
            53, 57, 62, 67, 72, 77, 82, 88, 94, 100,
        static bool buttonState;
        static int pwmIndex;
        static int pwmIncrement;
        static InterruptPort button;
        static PWM led;
            pwmIndex = 0;
            pwmIncrement = 1;
            buttonState = false;
            // NOTE: You will need to connect an LED to Digital Pin 5 on the Netduino board.
            // Use a 100-ohm (brown-black-brown) resistor between the LED anode (+) and Digital Pin 5.
            // Connect the LED cathode (-) to one of the GND pins on the Power header.
            // You can use any other PWM-enabled pin (5, 6, 9 or 10), but also remember to change
            // the Pin parameter in the PWM constructor below.
            led = new PWM(Pins.GPIO_PIN_D5);
            button = new InterruptPort(
                Pins.ONBOARD_SW1,
                false,
                Port.ResistorMode.Disabled,
                Port.InterruptMode.InterruptEdgeBoth);
            // Bind the interrupt handler to the pin's interrupt event.
            button.OnInterrupt += new NativeEventHandler(SwitchInterruptHandler);
            // Create a System.Threading.Timer instance and pass it the timer callback method.
            Timer pwmTimer = new Timer(
                new TimerCallback(PwmTimerCallback),
                null,
                pwmPeriod,
                pwmPeriod);
        public static void PwmTimerCallback(Object obj)
            // Only change the LED brightness when the button is pushed (true).
            if (true == buttonState)
                // Set the pin's new duty cycle.
                led.SetDutyCycle(gammaTable[pwmIndex]);
                pwmIndex += pwmIncrement;
                Debug.Print(gammaTable[pwmIndex].ToString());
                if (((gammaTable.Length - 1) == pwmIndex) || (0 == pwmIndex))
                    // The duty cycle has hit the min or max value.
                    // Start ramping in the other direction.
                    pwmIncrement = -pwmIncrement;
        public static void SwitchInterruptHandler(UInt32 data1, UInt32 data2, DateTime time)
            button.DisableInterrupt();
            buttonState = (0 == data2);
            button.EnableInterrupt();
~ David ~
#2 djcult
djcult
  • 3 posts
Posted 18 August 2010 - 11:59 AM
I acheived something similar by using an "easing function" (which I stole some from WPF). You can set an acceleration and/or deceleration ratio. I have an acceleration ratio of 100% which means it starts off slowly and then speeds up; thus the LED appears to fade in linearly.
Code is here if you're interested.
private const int AccelerationRatio = 1; // Start off slowly and speed up
private const int DecelerationRatio = 0;
private void EasingFade(FadeMode fadeMode, int periodInMilliseconds)
            var fadeIn = fadeMode == FadeMode.FadeIn;
            float progressRatio = fadeIn ? 0 : 1;
            while (fadeIn ? progressRatio <= 1 : progressRatio >= 0)
                _pwnPort.SetDutyCycle(ComputeEasedProgressRatio(AccelerationRatio, DecelerationRatio, progressRatio));
                progressRatio = fadeIn ? progressRatio+0.01f : progressRatio-0.01f; // Increment or decrement by 1%
                Thread.Sleep(periodInMilliseconds / 100);
        private static float ComputeEasedProgressRatio(float accelerationRatio, float decelerationRatio, float progressRatio)
            var combinedRatio = accelerationRatio + decelerationRatio;
            var num = progressRatio;
            if (combinedRatio == 0.0)
                return num;
            var num2 = (float)(2.0 / (2.0 - combinedRatio));
            if (num < accelerationRatio)
                return (float)(((num2 * num) * num) / (2.0 * accelerationRatio));
            if (num <= (1.0 - decelerationRatio))
                return (float)(num2 * (num - (accelerationRatio / 2.0)));
            var num5 = (float)(1.0 - num);
            return (float)(1.0 - (((num2 * num5) * num5) / (2.0 * decelerationRatio)));
#3 Chris Walker
Posted 18 August 2010 - 02:50 PM
Nice! I'm glad I brought a Netduino with me on vacation so I can play with this :)
#4 Omar (OZ)
Omar (OZ)
  • 564 posts
Posted 18 August 2010 - 03:17 PM
omg lol. you really do love this thing, just make sure you arent outside with those blinking lights in NY :(
#5 dab
dab
  • 54 posts
Posted 18 August 2010 - 09:49 PM
You mean you actually take vacation? :P
~ David ~
