4Display Shields - Drivers
Posted 02 February 2011 - 04:28 PM
Find them here: 4display shields drivers
Posted 02 February 2011 - 04:38 PM
http://forums.netdui...ch__1#entry7992
http://forums.netdui...ch__1#entry7521
using System; using System.Threading; using Microsoft.SPOT; using Microsoft.SPOT.Hardware; using SecretLabs.NETMF.Hardware; using SecretLabs.NETMF.Hardware.NetduinoPlus; using System.IO.Ports; namespace uLCD_144_Test1 { class uLCD_144 { private byte currentline; public static byte[] GetByteArray(string s) { return System.Text.Encoding.UTF8.GetBytes(s); } public SerialPort _COMPORT; public void TextHome() { currentline = 0; } public void init() { using (OutputPort d4 = new OutputPort(Pins.GPIO_PIN_A5, true)) { d4.Write(false); d4.Write(true); } currentline = 0; Thread.Sleep(2000); _COMPORT.DiscardInBuffer(); _COMPORT.DiscardOutBuffer(); this.write(new byte[] { (byte)0x55 }); WaitForACK(); TextMode(false); } public void WaitForACK(string note = "") { while (_COMPORT.BytesToWrite > 0) { } while (_COMPORT.BytesToRead == 0) { } dumpbuffer(note); } public void CopyPaste(byte startx, byte starty, byte endx, byte endy, byte width, byte height) { write((byte)0x63); write(startx); write(starty); write(endx); write(endy); write(width); write(height); WaitForACK(); dumpbuffer("CopyPaste"); } public void TextMode(bool transparent = false) { if (transparent) { write((byte)0x4f); write((byte)0x00); } else { write((byte)0x4f); write((byte)0x01); } WaitForACK(); dumpbuffer("TextMode"); } public void Print(string s) { if (currentline > 15) { CopyPaste(0, 8, 0, 0, 128, 119); currentline = 15; //DrawASCIIString(" ", (ushort)0xFFFF, (byte)0, (byte)0, (byte)currentline); } //DrawASCIIString(" ", (ushort)0xFFFF, (byte)0, (byte)0, (byte)currentline); dumpbuffer("print-cl"); DrawASCIIString(s, (ushort)0xFFFF, (byte)0, (byte)0, (byte)currentline); currentline += (byte)(s.Length / 21 + 1); dumpbuffer("print"); } public void DrawASCIIString(string s, ushort color = (ushort)0xffff, byte font = 0, byte x = 0, byte y = 0) //2.3.6 Draw “String” of ASCII Text (text format) - 73hex //Command cmd, column, row, font, stringColour(msb:lsb), “string”, terminator { byte[] textba = GetByteArray(s); write((byte)0x73); write(x); write(y); write(font); write((byte)(color >> 8)); write((byte)(color & 0x00FF)); write(textba); write((byte)0x00); WaitForACK(); } public void clear() { currentline = 0; write((byte)0x45); WaitForACK(); dumpbuffer("Clear"); } public void DrawPixel(byte x, byte y, ushort color = 0xFFFF) { this.write(0x50); this.write(x); this.write(y); this.write(color); WaitForACK("Draw Pixel"); } public void drawbitmap(byte[] bmp) { //2.2.5 Draw Image-Icon - 49hex //Command cmd, x, y, width, height, colourMode, pixel1, .. pixelN byte[] cmd = new byte[] { (byte)0x49, (byte)0x00, (byte)0x2A, (byte)0x80, (byte)0x28, (byte)0x08 }; this.write(cmd); this.write(bmp); WaitForACK(); } public void write(byte B) { byte[] ba = new byte[1]; ba[0] = b; this.write(ba); } public void write(byte[] ba) { if (this._COMPORT.IsOpen) { this._COMPORT.Write(ba, 0, ba.Length); //int sleeptime = (ba.Length / 7) + 1; //(calculate transmission time, at 115200, it can send 14 bytes / mx //Debug.Print(sleeptime.ToString()); //if (pause) //{ ///Thread.Sleep(sleeptime); //} } else { } } public void write(ushort us) { write((byte)(us >> 8)); write((byte)(us & 0x00FF)); } public void dumpbuffer(string note = "") { //_COMPORT. Debug.Print("(" + note + ") In buffer: " + _COMPORT.BytesToRead.ToString()); while (_COMPORT.BytesToRead > 0) { byte[] buffer = new byte[1]; _COMPORT.Read(buffer, 0, 1); Debug.Print(buffer[0].ToString()); } } public uLCD_144(string sp = SerialPorts.COM1) { this._COMPORT = new SerialPort(sp, 115200); this._COMPORT.Open(); this.init(); } } }
Posted 02 February 2011 - 04:46 PM
Hey, Omar, here's my uLCD-144 class, I haven't spent much time to round it out but it might have something useful for you. It still has a bunch of debug.print stuff. Also some links to my other threads in case it helps someone:
Nice code! I'll do my own though, if I don't write it I wont understand it. but I'm sure thats going to help a lot of people. I'll definitely be taking a look at it if I ever get stuck so thanks a bunch. I hope to include the 5 button joystick stuff too, since this is the shield and not just the screen.
Posted 02 February 2011 - 10:38 PM
Note the two handy "sprite" commands copyScreenToSD and copySDToScreen work well too; I used the application FAT-Controller to upload the sprites to screen
JP
Posted 02 February 2011 - 11:26 PM
Posted 02 February 2011 - 11:31 PM
The list of constants defining the command set is complete, but indeed their implementations as C# methods are not. I copied all the constants from the datasheet, and introduced the commands as I needed them, incrementally like everyone else. However I'm content with this subset so far for my own applicationQuiche31, is that "command complete" for SGC? Either way, awesome, the color constants alone are great!
Posted 04 March 2012 - 01:58 AM
