FileStream fOut = File.Create(@"\SD\downed"); HttpWebRequest req = (HttpWebRequest)WebRequest.Create("http://example.com");//"http://feeds2.feedburner.com/the404/"); HttpWebResponse resp = (HttpWebResponse)req.GetResponse(); Stream respStream = resp.GetResponseStream(); int read = respStream.ReadByte(); while (read != -1) { read = respStream.ReadByte(); fOut.WriteByte((byte)read); } respStream.Close(); fOut.Close();
MF alternate to Stream.CopyTo
Started by spaceyguy, Feb 01 2011 11:03 PM
7 replies to this topic
Posted 01 February 2011 - 11:03 PM
I was trying to duplicate the effect of using the Stream.CopyTo, so that I could redirect the output of a HttpWebResponse response stream to a FileStream. I created the following to as an attempt; it works on regular .Net but not on the netduino+.
Posted 01 February 2011 - 11:36 PM
Hi spaceyguy,
What is the result if you try doing that with .NET MF?
Posted 01 February 2011 - 11:56 PM
I'm trying to download the requested page.
Posted 02 February 2011 - 12:00 AM
Sorry, let me ask that another way...what error are you getting when you run the code? Is a feature not implemented? Do you get an exception?
Posted 02 February 2011 - 05:44 AM
Whatever other issues it may have, it also seems to have a bug, as it unconditionally throws away the first byte read without copying it. You probably want:
while(true) { int read = respStream.ReadByte(); if(read == -1) break; fOut.WriteByte((byte)read); }
Posted 02 February 2011 - 07:12 PM
Thanks Corey, I knew there was a better design but I was having a mental block preventing me to find one.
Chris as for what actually happens, after 5 minutes I get the following:
The thread '<No Name>' (0x2) has exited with code 0 (0x0). #### Exception System.Net.Sockets.SocketException - CLR_E_FAIL (1) #### #### Message: #### Microsoft.SPOT.Net.SocketNative::recv [IP: 0000] #### #### System.Net.Sockets.Socket::Receive [IP: 0018] #### #### System.Net.Sockets.NetworkStream::Read [IP: 0062] #### #### System.Net.InputNetworkStreamWrapper::RefillInternalBuffer [IP: 0038] #### #### System.Net.InputNetworkStreamWrapper::ReadByte [IP: 000e] #### #### DownFile.Program::Main [IP: 0026] #### #### SocketException ErrorCode = 10060 #### SocketException ErrorCode = 10060 A first chance exception of type 'System.Net.Sockets.SocketException' occurred in Microsoft.SPOT.Net.dll #### SocketException ErrorCode = 10060 An unhandled exception of type 'System.Net.Sockets.SocketException' occurred in Microsoft.SPOT.Net.dll
Posted 02 February 2011 - 09:20 PM
spaceyguy,
It looks like the final ReadByte() is waiting for a timeout of 5 minutes before throwing a timeout exception of sorts.
Do you get all of your data before that call? Perhaps the ReadByte() call is improperly timing out instead of just returning EOF?
Posted 03 February 2011 - 12:30 AM
It only creates the file, nothing is output into it.
EDIT: When I substituted respStream with a FileStream it did work, if that means anything.
EDIT 2: I changed the page that it requested and it was successful.
