Netduino Firmware v4.1.1 ALPHA 6
5 replies to this topic
#1 Chris Walker
Posted 31 January 2011 - 11:30 AM
Version: 4.1.1 ALPHA 6 (version 4.1.1.0 a6) [replaced by 4.1.1.0 a7]
#2 Terry Fogg
Terry Fogg
  • 4 posts
Posted 10 February 2011 - 02:57 AM
After deploying the new image, using mfdeploy it stopped with a dialog box at the end with executing application... I pulled the usb plug, and plugged it back in and enquired for the device capabilities,which indicated that the deploy may have worked based on the update HAL version. I then used the board with VS2010, simple loop with led flash. VS2010 deployed assemblies, but gets stuck at "Rebooting..." Managed to reset the board during the debugging,and somehow managed to get a breakpoint hit and could step the system,so code looks like its getting into the device. Cannot proceed any further at the moment with this system without a fix. I have code written for the Nokia 6100 display(Sparkfun) and require the variable bit SPI to try to get it working. Terry
#3 Fabien Royer
Fabien Royer
  • 406 posts
  • LocationRedmond, WA
Posted 10 February 2011 - 08:35 PM
Chris, Has anything changed in 4.1.1 alpha 6 with SecretLabs.NETMF.IO.cs? If so, would you mind sharing the source in the .zip as well? Thanks, -Fabien.
#4 Chris Walker
Posted 10 February 2011 - 08:40 PM
No.
#5 Terry Fogg
Terry Fogg
  • 4 posts
Posted 15 February 2011 - 02:07 AM
Hi, From my previous post I have had problems deploying the ALPHA versions. I have now ALPHA 7 working with the following method. I deployed the ALPHA7 version and the deploy process hung at "Executing application" dialog box. I pulled the usb from the netduino, reconnected and use device capabilites to confirm that the firmware was loaded. I then used the erase managed application from MFDEPLOY, it erased some sectors, the rebooted successfully. It now works using VS2010 okay Terry
#6 ILikeInternets
ILikeInternets
Posted 12 March 2011 - 05:07 PM
Terry
Mine hung at "Executing application" as well. I followed these steps except for the last one (erase managed application - not sure what that means) and it appears to be working ok...
