Best Answer shiv.kumar, 26 January 2016 - 03:38 PM
In order to configure the Wi-Fi (as HSven1611 mentioned), one has to use th eMFDeploy tool. One can find this tool in the .NET Micro framework SDK (something I didn't know about - that is where to find it). for the SDK version 4.3 it can be found here
C?:\Program Files (x86)\Microsoft .NET Micro Framework\Tools\
Once I found it, I was able to configure the Wi-Fi with the DNS server's IP address as well as the WPA from the Target | Configuration | Network menu option. The dialog presented has the fields you'll need to fill in. Make sure your device is connected to your PC.
