Netduino Plus and UART 7 bit problems
1 reply to this topic
#1 MicroEmb
MicroEmb
  • 12 posts
Posted 02 January 2016 - 05:23 PM
Hello
Just a quick question if some one or the staff have experience problem using 7 bit UART settings on the Netduino Plus (first version) ?
I have developed a small UART app that receives chars on UART1 and UART2  looking for some chars
and light up status leds.
However i have developed it under 115200 baud 8N1 and it works OK but when i changed to 9600 Baud 7E1
i got faulty chars, i have tested to change to 9600 8E1 and that works so it is 7 bit that is the problem.
Is this a known issue on the Netduino Plus or the firmware ?
I use 4.2.0,0 and Framework 4.2
#2 MicroEmb
MicroEmb
  • 12 posts
Posted 03 January 2016 - 09:29 AM
I have investigated this further and it is only UART1 that have this problem with 7 Bit.
I have checked the byte that i receive  to UART1 and it is always in 8 bit mode , the MSB is always 1
So as an example i should receive a right bracket ] witch is 0x5D 93d and that is received as 0xDD 221d
the MSB is 1   if i send with 8 bit it receives OK 0x5D 93d
So as a workaround i substrate 128 from received byte to get it right,
